93 More
Old May 21, 2006 | 10:25 AM
qws's Avatar
qws
Default 93 More
Ever since I started mods on the car my goal has always been 300 rwhp. I'm pretty sure I can achieve this but need your help. As you know I'm limited with the CFI, (1984)but I would like to do this with still using the CFI. Heres my dyno sheet (follow the link)
http://forums.corvetteforum.com/show....php?t=1397167
so I have a couple of questions for you.
1) I already plan on changing my gears to 3.07, I do have an automatic transmission
2)Cam recommendations- I can't go to wild since the CFI won't flow that much fuel. Can I get larger injectors for this? Do I need to bore my TB's out? If I do will this mod cause me to loose any low end?
3) Head recommendations? The guy that had the dyno told me I probobly don't need to change the heads, he was more concerned about how much flow the TB's can flow.
Is there anything else you guys can recommend? I don't want to use a bottle either.
Old May 21, 2006 | 10:28 AM
Pete K's Avatar
Pete K
3:07's are nice. You will like them. I would suggest a cam in the 210 duration intake area and as much lift as it will allow. Fuel injected stuff seems to like a bit of "over lift"
