codes 27 and 21
Thanks for the help
Cleared codes and drove car for a while, Idle was normal. When I shut it off and restart the fast idle returns. Read codes again, got 21, 64, 65. Changed the TPS, cleared codes and restarted. Fast idle still and codes are 64 and 65 only. These codes never clear from the ECM. If I clear the codes, do not start the car and read codes again 64 and 65 are still there. Anyone with any suggestions. HELP please.
DTC #64: Bank 2 RF Heated Oxygen Sensor #1 Circuit Lean.
DTC #65: Bank 2 RF Heated Oxygen Sensor #1 Circuit Rich.
First the codes will have to be cleared, then if the high idle still exist we'll start from that. You stated you changed the O2 sensors. Did you check the circuit to make sure it is sending the right signal to the PCM?
No i did not check the circuit. How does one go about checking it?
First you need to find out if the 95 and 94 codes are the same. I would do a visual inspection of the wire (could be touching the exhaust or grounded). If the codes are the same a rich/lean on the same circuit is either a bad O2 sensor or faulty connection. They sell an adapter to put between the connection so you can check the volts. It ranges between .1v (lean) to .9v (rich). Or you can get a diagnostic scan to check voltage. I think if you replaced that O2 sensor with a new one and still have the same problem, then the circuit is problem.
