113 head question.
Old May 21, 2006 | 08:33 PM
85C4fanatic's Avatar
85C4fanatic
Default 113 head question.
I have an 85 with its stock heads and headman LT headers. Would there be any problem putting 113's on as replacement heads? Will the Headmans bolt up to the heads correctly? I do have an 88 lower intake if I need to use it. I know I would have to plumb an external EGR line correct. THanks for the help.
Old May 22, 2006 | 03:02 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
The problem MAY be the spark plug angle to the headers bolt on clearance...if those headers you have can clear angled plugs,I dont see a problem...if the plugs on your engine is straight and not "angled" and the headmans are made for that,there will be a problem attaching them to later heads...thats pretty much the bolt on problems people have with headers on these engines..check clearances to see if its gonna be a problem or not...
Old May 22, 2006 | 07:21 AM
85C4fanatic
That totally slipped my mind. Thanks for reminding me to look at that.
To 113 head question.
