Ignition problem?
Old May 21, 2006 | 09:12 PM
Getzen88's Avatar
Getzen88
Default Ignition problem?
my 88 is "missing", when i go wot, i get a chugging until i let up. also, when i have the radio on, i get interfearance with the radio that sincs up with the chugging. could this be a plug, wire, rotor or what?
Old May 21, 2006 | 09:29 PM
bogus's Avatar
bogus
start with wires.
Old May 22, 2006 | 11:02 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Open the hood in a dark garage or at night. Look for electrical arcing on the ignition wires.
Old May 22, 2006 | 12:23 PM
Getzen88's Avatar
Getzen88
i did the hood open at night and couldn't find any arcing. what other tests could i do?
Old May 22, 2006 | 02:26 PM
rick lambert's Avatar
rick lambert
If you've got a DVOM digital voltage ohm meter, you can ohm the plug wires. They should ohm around 5000 per foot.If you've got a break inside you won't see the arcing.
To Ignition problem?
