Electrical - This should be so easy...but...
I am missing voltage on numerious fuses. It's not like the voltage is on one leg of the fuse and not the other (like a blow fuse). I don't have voltage getting to either leg of the fuse on the inside fuse box. I truly don't know what all of them do... So even if you have one bit of info, I apprecite it.
(1993 Book 2, Page 8a-11-0)
Fuse #5 Htd Mir (Heated Mirrors)
Fuse #9 Crank Air Bag (I know what an Air Bag is, Whats a Crank?)
Fuse #10 Crank P/N Clutch (?)
Fuse #11 RH Illum (?)
Fuse #12 LH Illum (?)
Fuse #13 Cnsl Illum (?)
I have checked all "UnderHood Fuse Block #1 and #2. I have voltage on both legs of the fuse there. So what do these things have in common?
Lastly, FYI to all 93 owners, I'm not sure if this is a mistake in the book #2, Page 8A-11-10.... But if you pull/blow the fuse marked A/C clutch fuse (Fuse #18), you will also loose voltage on A/C Midl (Fuse #20). The book shows that they are on seperate lines, but it looks to me that Fuse #18 feed Fuse #20. (So chime in and let me know what you think)
Good luck
