What headers for AFR angle plug heads?
Old 08-25-2001, 12:41 PM
codyusa
codyusa's Avatar
CI 5-6-7-8-9-10 Veteran
Default What headers for AFR angle plug heads?
Hookers will not fit, per hooker. It is an '87. What are my options? Thanks
Old 08-25-2001, 08:52 PM
ol,RJ
ol,RJ's Avatar
Default Re: What headers for AFR angle plug heads? (codyusa)
I"ve got the AFR angle plug heads and running TPIS headers. fit is pretty good, some of the plug wires are close to header but I can get the plugs in and out pretty easy. just wish they were thicker tubing or stainless steel?
RJ
Old 08-25-2001, 09:43 PM
mackeyred96
mackeyred96's Avatar
Location: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
What is the difference between AFR angle plug heads and stock LT1's?
Old 08-26-2001, 12:06 AM
HWoods
HWoods's Avatar
Default Re: What headers for AFR angle plug heads? (mackeyred96)
I have an 86 with the AFR angle plug heads, and I have the Hooker 2149 Headers on it. You have to remember, Holley recently bought Hooker out, and their tech is maybe not what it should or could be. You will need to cut a slot in a spark plug socket to get to several of the plugs, but you can get them out. you will need to notch out about 3/8 or an inch out of the socket, but not all the way to the end, so that it can grip the plug. Don't have a digi camera or I would post a pic of mine.
Old 08-26-2001, 05:12 PM
black bart
black bart's Avatar
TPIS WILL FIT AND YOU WON'T HAVE TO BEAT BANG OR GRIND TO PUT THEM ON OR TO CHANGE PLUGS. BUY WHAT IS MADE FOR YOUR CAR INSTEAD OF GENERIC FIT EVERYTHIG FIT NOTHING HEADER
:cheers:
Old 08-26-2001, 08:01 PM
89vette
89vette's Avatar
Default Re: What headers for AFR angle plug heads? (black bart)
I beg to differ Black Bart. I have both the TPIS headers and AFR angle plug Vette heads. Number 7 tube needs to be banged in pretty good to clear. Lots of peopel also report this. Plug changing is als easy.
Old 08-26-2001, 08:14 PM
black bart
black bart's Avatar
Default Re: What headers for AFR angle plug heads? (89vette)
Maybe you have older headers than i have mine clears so well that i even put several wraps of header wrap around mine and still have room to remove the plugs. I don't know but perhaps they have changed them but mine is perfect fit only thing i don't like is the increased heat in the car even with wrap the stock exhaust was cooler :boxing
Old 08-26-2001, 08:29 PM
korvetkeith
korvetkeith's Avatar
Uh? Your car is awesome? :eek:
[Modified by korvetkeith, 6:31 PM 8/26/2001]
Old 08-26-2001, 09:36 PM
mackeyred96
What size tubes do you have?
Old 08-26-2001, 09:41 PM
HWoods
HWoods's Avatar
The Hooker's are 1 3/4 inch. the fit is excellent, just need to work a little to get the plugs out, but can be done.
Old 08-27-2001, 03:57 AM
Warlock
Warlock's Avatar
Having recently gone through this...there are three styles of AFRs: Straight, angled, or L98 Angled. If you have the L98 angled you should be fine. If you just have the angled, don't bother with the hookers.
Old 08-27-2001, 12:08 PM
black bart
black bart's Avatar
Default Re: What headers for AFR angle plug heads? (Warlock)
Thanks warlock for that info I knew mine fit perfect i have AFR heads with the
L 98 angle and when i ordered my headers i told them i had L98 angle and they said they would fit and they do. Just one more thing that a person has to look out for when modifying his engine. That is what is good about this forum is to share experiences and maybe keep someone from making costly mistakes that we already made. :seeya :seeya
To What headers for AFR angle plug heads?
Quick Reply: What headers for AFR angle plug heads?
