Time to dynamite my LT-1
Things I've done.
Cleaned throttle body and IAC enclosure, new gaskets.
No leaks at throttle body shaft
New IAC
New TPS
Removed (2) vacuum lines from intake and capped fittings for test, no change
Removed and capped evap control line from solenoid, no change
Replaced PVC valve and lines
Sprayed intake with starter spray to look for leaks, can't find any.
WHAT ELSE IS LEFT??
Wild a*s guesses.
Intake manifold leak, even though spray doesn't show it. No water or oil leaks.
A/C request signal to ECM even though A/C is off
Sponge TPS gasket leaking, even though spray doesn't show it
Either I find an answer or I get out the dynamite
HELP.
Larry
IAC is new. Problem exists when doing minimum air adjustment with IAC disconnected from ECM.
IAC was set at 28mm per spec before install
TPS is new but problem existed before I changed it. TPS is not adjustable on LT-1. I did not reset with an Tech-1. I don't recall seeing that in manual.
I did not check EGR vacuum. I would expect to see trouble code if EGR was sticking. Am I wrong? Idle is not rough which is what I would expect with a stuck EGR. Its smooth but high.
Thanks for help. Keep ideas coming.
Larry
Larry
