L98 oil distribution question
i have set oil pump pick-ups at 1/4--3/8 above floor of oil pan on hundreds of small blocks with great results....i have heard some recent reports of going higher, but i'll stick with what is proven
around the perimeter of the housing to openings on either side
that feed the lifter galleys.
The pass side lifter galley enters the hole that supports the bottom
of the dist housing. If the housing is in place, oil flows around it
to the galley on the forward side of the dist housing hole and goes
forward to the pass side lifters. If the housing is NOT in place, there
will be a massive leak where the cam bearing-to-dist housing galley
terminates at the back side of the dist housing hole. The oil will
flow down into the crankcase.
Aftermarket tools have a casting at the bottom to seal the housing
hole in the same manner that the dist housing does.
questions more visible for those who do
- I want to know if I turn the oil pump with the priming tool should I get oil
out the top center whole in the lifter. Or does oil only come out there,
if the lifter is being pushed on by the cam? - What is the proper way to prime the lifter prior to installation. The
way I always primed lifter was to submerge them in oil overnight before
install. Now these are the newer roller lifters, so is this the correct way? - What is the correct height to set the oil pickup relative to the pan?
i.e. one inch up from the bottom, 1/2" etc.
3/8 - 7/16 from the pan.
I have not worked with hyd roller lifters. I recall that priming flat
tappets resulted in oil moving up the pushrods from the center holes
in the lifters but it's been so long since I've done it, I'm really no
longer SURE of this.
I used the overnight procedure for flat tappets, and spun a priming
tool in the distributer opening immediately before starting. I ran the
tool long enough to see oil pressure build and stabilize on the gauge
- if I couldn't build pressure, the engine didn't get started.
Incidently, the 18V cordless drills are GREAT for priming, IMO.
I preoiled all but my last BBC with a home-made shaft made from a bit
of round stock (no collar.) There was pressure on the gauge each
time so that tells me that the main and rod bearings got oil. The cam
and lifters were probably short-changed but I was always generous
with EOS and moly during assembly so perhaps that helped me
avoid trouble back then.
Actually, I think I primed my first with a big screwdriver, now that I
think about it. No pressure, but at least there was oil in the galleys.
FWIW, I recently read a piece that said that as a SBC winds up thre will be from 3 1/2 to 4 quarts of oil distributed throught the engine. That means only 1 to 1 1/2 quarts in the pan. This is the reason for the pick up to be 3/8 to 7/16 from the pan.
