'90 L98 stumbles when cold
Scott
Now, when your engine smooths out when it is hot, the O2 sensors are now brought into the AFR equation, or "closed loop" operation. Now that the O2 sensors can feedback the oxygen content of your exhaust, the PCM can now make short term fuel adjustment to correct the AF ratio. So I am theorizng that the faulty,or out of spec. sensor is being succesfully compensated for by your O2 sensors....
gccsv ==>"the OPPOSITE seems to happen when the Oxygen sensor goes bad".
Correct, a bad O2 sensor will foul up the AFR calculations during "closed loop" operation, and have no effect during cold operation. However, keep in mind that the O2 sensor feedback to the PCM is ignored during WOT even during "closed loop".
Just a theory.....(the MAP/MAF are used on LT1's, and I am not sure what your L98 uses for AFR management, but just apply to your systems sensors.)
So, in a perfect world,your ECM should trim your fuel using the O2 feedback and "lean out" your AFR. But it seems as though you are running rich at all times, so something is prohibiting your system from running and maintaining the magical "stoichioemetric" AFR of 14.7/1 ....(rich would mean something like an Air/Fuel of 14.4/1 which translates to LESS air per unit fuel. A lean condition would be something like 14.9/1 or MORE Air to unit fuel)
Assuming your MAF/MAP are working properly:
-check that you do not have excessive fuel pressure in your fuel rail. This would cause an uncontrollable rich condition by forcing more fuel than intended when your FI's open. Think of your FI like a sprayy nozzle at the end of a garden hose. If you put the water pressure low, and squeeze handle for 1 second and release, you will not get that big of spray of water. Turn up the water pressure, squeeze the handle for 1 second and release, and you get much more water during that short time frame. Since ALL of your plugs are fuel fouled, I would look at this first.
-By all means, remove and inspect your O2 sensor. Just don't be convinced that this is the culprit.
*** Didn't mean to steal this thread but it just kinda happened... ***
Question #1, does your engine run rich during cold start as well as when it is hot? If so, this may indicate your O2 sensor is OK, because it is NOT used for AFR calculations until engine hot.
Question #2, can you easily remove your fuel rail to see if you have leaky injectors? On my LT1, I could remove fuel rail assembly in about 10minutes. An easier way would be to hook up your FP gauge, turn ignition to "on", let the pressure build to peak, ignition "off", watch to see if pressure drops noticably over a short period of time(let's say 10 or 15 minutes). At 89K miles, your FI's may be worn out.
