Ready for performance mods on 90 L98 - advice?
The bad news is the Fuel injectors are shot and a head gasket leaks. The dealer was insane with the quote to fix it (I could almost buy a new engine).
This sounds like the time for some upgrades!
I read Vader's site on mods and have some ideas and would love comments and suggestion. I am not a mechanic and will be having a professional do the work.
I would like to see 350HP or so (and lots of torque - I love torque).
So far I see that I will need to replace the cam, intake, exhaust, and doing some head work.
I'm thinking I will go with Hooker headers and turn the car into a true dual setup with Corsa mufflers and some form of high flow cat.
Vader seems to like the superram and I like his reasoning. Any recommendations where to buy (the intake or any of the parts for that matter)?
Since I need new injectors anyway - should I go with 24# or 30#? It looks like I'll also want to add an adjustable fuel pressure regulator.
He suggested the Accel219 cam for this intake - sound good?
Since I have '113 heads (that need to be resurfaced anyway) I was planning on having them ported and keeping them. People seem to like them.
O.K. - what did I miss? Should I rethink any parts of this? My budget is flexible (the sky is not the limit, however) and I want a quality, drivable car when I am done.
24 lbs injectors should be fine, but that is really for you and your tuner to decide.
Who will be doing the mechanical work? If you are already into the heads, you should freshen up the bottom end, and if you are doing that, think about going with a 383 - you'll LOVE the torque
After that you will need to think about the torque converter.
Your best bet is to find the SR used on ebay. Any of the bases work and I would match the ports to the heads after those are done.
Larry
Xtreme Energy XR270HR Hydraulic Roller Camshaft Only
Operating Range: 1600-5400 RPM
Duration Advertised: 270° Intake / 276° Exhaust
Duration @ .050'' Lift: 218° Intake / 224° Exhaust
Valve Lift w/1.5 Rockers: .495'' Intake / .502'' Exhaust
Lobe Separation Angle: 110°
This discussion has added some thoughts for me. How much of a bigger deal would it be to do the bottom end at the same time (aka - 383)? I do not have a good sense of the cost of much of this stuff, so I assumed that it would add quite a bit to the bottom line expense of the project.
Thanks to everyone for their suggestions so far.
