Brass plug where temp sensor should be
Old May 22, 2006 | 09:35 PM
archangelus2's Avatar
archangelus2
1st Gear
Default Brass plug where temp sensor should be
Hi all,
I have a 1994 Z28 which I had to replace the heads on as the last owner mollested all of the the manifold bolt holes. Anyway. I bought a set of used heads off of ebay that were supposedly off of a 1995 lt1 corvette and had no problems installing them accept for one thing.
Where the temperature sensor was on my old heads there is now what seems to be a brass "plug" which has a hole that is perfectly square and measured with a micrometer seems to be 5/16". I have tried ratchets of sizes 3/8" and 1/4" and neither fit. And no the hole is not hex, it is square - four sides.
I assume I need to get that thing out of there somehow so I can screw in a temp sensor. If anybody has any ideas on what/why that thing is there and how to get it out....preferably some type of tool I would be highly appreciative. Thanks a bunch.
-Gabriel Terrel
Old May 22, 2006 | 09:42 PM
dock351's Avatar
dock351
St. Jude Donor '06
I ran into this problem too...looked all over the place for the right tool...i called my auto tech neighbor over, and he went back to his garage, used a grinder to cut down an old tool he had laying around to the correct size and had it removed before i could blink twice.
Old May 22, 2006 | 10:02 PM
xflagz51's Avatar
xflagz51
When I installed the JET Performance fan switch in my '90 I had to remove a square plug in the drivers side cylinder head. I went to NAPA and they suggested buying a 3/8" drive extension that was on the sale rack and grinding it down to fit, worked like a charm!
Happy Wrenching,
Adam.
PS, with tools of course, but have a beer too!
Old May 23, 2006 | 12:07 PM
STL94LT1's Avatar
STL94LT1
Why not just extend the sensor wire to the opposite head?
Old May 23, 2006 | 12:49 PM
pcolt94's Avatar
pcolt94
I have a open end adjustable wrench which I then put a pipe over the end to give me additional leverage for special times. Tighten it as tight as you can get it. I hope you don't snap the sucker off, it sounds like its been in there a long time. In the mean time I would start putting some WD-40 on it for a day before I really attacked it.
I think I have seen sockets or tools that receive those square heads. You might check locally to see if you can find something.
To Brass plug where temp sensor should be
