Q about Diff. removal procedures.
Old May 23, 2006 | 02:25 AM
Klondike's Avatar
Klondike
Default Q about Diff. removal procedures.
I'm removing my Dana 44 from my 96LT4 for service. When you loosen the C-beam how do you support the tail end of the engine/trans assy.? Right now I have a piece of angle iron across the front legs of the lift and the rear of the transmission is resting on that. I was wondering how other people have done it. I don't want to damage the shifter or boot on the top side by letting it fall too far down.
Also, when the rear wheels are off the ground, is enough tension off the spring to remove the end bolts, or do you have to support the spring ends (still too much tension) before removing the bolts? I'm wondering how far down the spring ends will go before it relaxes. I don't even want to get smacked by it if it is still loaded.
Old May 23, 2006 | 02:35 AM
Fubar569's Avatar
Fubar569
when i dropped the C beam in my auto 84, i just used a small floor jack with a block of wood to support the trans...actually it's still under there right now!
Old May 23, 2006 | 03:08 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If you have the base model springs, you may need to compress them a bit to get the bolt started. You might even be able to do it by hand though.
The stiffer Z51 springs have less arch to them.
I think a 2x6 laid across your lift, with some wood spacers would be enough to support the trans. Remember, the further back you support it, the less strong of a support you need.
Old May 23, 2006 | 08:45 AM
Klondike's Avatar
Klondike
Thanks, It looks like I'm OK so far. The "grand opening" will be tonight.
Old May 23, 2006 | 12:01 PM
bowtie racing's Avatar
bowtie racing
I havent ever seen better answer like this!!!!
The pic video is really cool!!!!!!!!
Old May 23, 2006 | 02:49 PM
Grace91's Avatar
Grace91
That is way too cool.
When I pulled my D44 I had to jack the knuckle a little bit to get the spring pressure off before I could loosen the castle nut. Same thing when I put the thing back together. There is not a ton of pressure left on the spring when the tires are off the ground, but just enough so you can't get the nut on or off without a little bit of jacking.
Old May 23, 2006 | 10:12 PM
thirdtimevetteowner's Avatar
thirdtimevetteowner
Is there any way of playing that super cool video in slow motion?
Old May 23, 2006 | 11:32 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
And in reverse too.
Old May 23, 2006 | 11:59 PM
CentralCoaster
Yeah, take 5 tabs of No Doze. Guaranteed to slow it down.
Old May 24, 2006 | 12:35 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
https://www.corvetteforum.com/techti...=218&TopicID=2
Old May 24, 2006 | 05:49 PM
Klondike's Avatar
Klondike
Default Guts Update. Got it out!
With help from a couple of friends, one with a lift & another with good hands, we got it pulled last nite. Driver side yoke is OK with recomended .005" end clearance between cross shaft & axle tip. Passenger side still had the clip on it but the clearance was .110" Had a pair of snap ring removers from work that made removing the stub axles quick. Pass side looked like it had been machined off and the cross shaft didn't have a mark on it! Talked to a local Vette axle & drive shaft guy and he said "That's the way they normally wear out". He's got a replacement located a state or two away for $175.00 and after spending the day looking around town and a visit to a machine shop that had a $200 minimum charge, it looks like time to give the man a call back. I guess these Dana 44's, and parts for them, are hard to come by.
P.S. Thanks to all who responded & Central Coaster....That's a really cool video. Except for the license plate and mufflers, that even looks like my car!
To Q about Diff. removal procedures.
