Clicky U-Joints
Old May 23, 2006 | 01:45 PM
Medicman55's Avatar
Medicman55
Default Clicky U-Joints
Hey everyone,
I know that the search button is my friend, but this is a different question. The U-joints in the '86 are starting to click, but its only when I accelerate quickly. Its also only on one side. Since U-joints are a major job, and I will probably put them off for a while, how much longer do I have before they break? When I finally get around to replacing them, should I just have someone else do them, and how much will it cost?
medic
Old May 23, 2006 | 02:50 PM
Jims1988C4's Avatar
Jims1988C4
Once my U-joints started clicking it was about one week before I was told to fix it. Don't let a dealer do it !! Read my posts about my experince.I replaced all 4 half shaft ujoints. It should cost you no more then $700 including labor and parts. Good luck
Old May 23, 2006 | 03:01 PM
geezel's Avatar
geezel
I paid $495 for all (4) half shaft u-joints (Spicer) installed.
Old May 23, 2006 | 10:28 PM
JackDidley's Avatar
JackDidley
U joints are cheap and not hard to replace. Click the link. http://personal.tmlp.com/scorp/vette...nts/index.html
Scorp did this for you.
Old May 24, 2006 | 06:52 AM
hip's Avatar
hip
If you have a vise you can replace all 6 in an afternoon look at a manual no big deal, well worth buying a vice & save $500 labor
Old May 24, 2006 | 08:45 AM
Joe C's Avatar
Joe C
"...in an afternoon..." i must be real slow, or (no flames) you're real fast. it took me the better part of a weekend to replace all six. i bought 6 "brute-force" HD u-joints at around $100. i didn't feel real comfortable pressing out/pressing in the u-joints in the aluminum half shafts and drive shaft, so i took mine to a local machine shop. they charged me $40 labor. my total investment was around a buck and a half. its no big deal, but to drop the drive shaft, the manual says to remove the c-channel brace (from the transmission to the differential) - WTF GM ! i droped the driveshaft and saw where the interference was - took a die grinder and ground away about .125 x 1.5 inches of some sheetmetal substructure near the differential. driveshaft came out without removing the c-channel. hell, it took me the better part of an afternoon to jack up the car and remove the exhaust - i guess the older i get, the slower i get...
Old May 24, 2006 | 10:20 AM
Muffin's Avatar
Muffin
What Joe C said. I did mine as a part of an engine/tranny swap so I can't comment on time but U-joints are not rocket science and can be done by anyone with reasonable skills and tools.
Medic, I don't think I would wait too long. The results of a U-joint breaking at 60 MPH is not pretty.
Old May 24, 2006 | 03:58 PM
CP5150's Avatar
CP5150
Originally Posted by Medicman55
Hey everyone,
medic
I have a clicking I think is comming from the drivers side. Brought it to the dealership twice while it was still under warranty. They insisted it might be my rearend going bad, but the u-joints and everything else were "tight" as they put it. A year later and nothing has changed. Still clicks but it has not gotten any worse. I never believed them though. I always thought it was a u-joint. Maybe it's time for a third party to take a look at it?
Old May 24, 2006 | 08:01 PM
GlennS87's Avatar
GlennS87
I recently had all my u-joints replaced using Spicer's, and I am still getting the clicvking that you described. It's driving me nuts. Next up new ball joints and control arm bushings.
Old May 26, 2006 | 09:52 AM
Joe C's Avatar
Joe C
you might want to check for any play in the rear bearing/hub assemblies -
Old May 26, 2006 | 10:15 AM
SJW's Avatar
SJW
If this is truly a U-joint noise, I'd recommend that you do not delay the repair. Pole-vaulting a Corvette on its driveshaft can be as dangerous and destructive as a windmilling half-shaft, and a U-joint that fails can lead to either of these nightmares, depending upon which joint lets go.
Be well,
SJW
Old May 26, 2006 | 12:44 PM
quickcat's Avatar
quickcat
Are there any documented cases of this happening?
Old May 26, 2006 | 12:55 PM
Blownfuel1's Avatar
Blownfuel1
Never seen a Corvette do it, but I have seen a '34' Ford pick up drag car do it up close. Also, there used to be a really ugly video of a SS/MP C3 running up and over both rear slicks immediately after launching on NOS's website, but haven't seen it (or their site, for that matter) in years.
Old May 26, 2006 | 01:43 PM
scorp508's Avatar
scorp508
Is it all the time, or just when you get moving from a stop? If just from a stop have them take a look at and maybe replace the washer that goes between the 36MM nut and the spindle through the wheel bearings.
Old May 26, 2006 | 01:54 PM
SJW's Avatar
SJW
I know several guys who've had half-shafts windmill on them, and the destruction it caused was mighty impressive. Recall also that this shaft resides directly behind your seats. Trust me, you don't want a half shaft getting loose at one end. Half-shaft loops are a good idea with mega-torque engines in Vettes that will see hard launches.
There is plenty of history of vehicles pole-vaulting when the front end of the prop shaft drops. This is why drive shaft loops exist. Can't say I know of any Corvettes doing it, but why would you take that risk with known-bad U-joints?
Be well,
SJW
Old May 26, 2006 | 05:30 PM
JackDidley's Avatar
JackDidley
Just a comment on main driveshaft u joints. The shaft stays on a nearly fixed plane. The trans does not move much and the pinion does not move much. The C beam limits this. For that reason these joints last nearly forever. The half shafts moves with every bump in the road, so they work very hard and dont last as long. My 2 cents.
Old May 27, 2006 | 11:16 AM
super89's Avatar
super89
I recently replaced the u-joints on the driver's side of my car. It was making some really ugly noises, grinding sounds, clicks, etc. I was quite startled by it and grounded the car until I found the cause.
This is what had happened to the end cap on the inboard u-joint. The needle bearings had been pulverized into dust, and the trunnion strap holding the u-joint down was loose....very loose. I was glad I decided to check it out, I was driving on borrowed time as it was. Took me about 2 days to get the parts and do the work. Scorps' tech article on the issue was extremely helpful.
To Clicky U-Joints
Old May 27, 2006 | 11:45 AM
MrRenoman's Avatar
MrRenoman
Clicking has been covered many times on this forum.
The u-joints always seem to be the first area that members identify as being the problem and has been the problem on some cars.
Lubing the splines between the bearing assembly and the outboard universal joint yoke has solved the clicking problem and has been reported on this forum by members. This area gets rusty and for whatever reason causes a clicking sound. Lubing with anti-seize compound worked for me and others.
Art
Old May 28, 2006 | 04:49 PM
John A. Marker's Avatar
John A. Marker
Default Thanks Mr Renoman
I have had the "clicking" U-joints also. I replaced all the U-joints with good spicers. They did need replacing on the half shafts. So I know that they are good. I had already replaced the rear bearings a couple of years back and had used anti-seize on the splines when I installed them. Read your above suggestion.
This morning I ripped into the rear end. I used plenty of anti-seize on the splines, REALLY COATED THEM. Put it all back together and NO CLICKING... GREAT
Thanks for your help and suggestion.
Old May 28, 2006 | 05:22 PM
Medicman55's Avatar
Medicman55
I've been driving around, trying to lay off the U-joints since I havent had the time to replace them. I got to thinking about it, what would it take to replace a wheel bearing? I think that could possibly be what is making the clicking sound since the rear drivers side is the only thing that makes sound.
Medic
