Cracking Sound from Steering Rack
Old May 24, 2006 | 08:38 AM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Default Cracking Sound from Steering Rack
I have a cracking sound coming from what seems the middle of the steering rack. Here's the details:
When the car has been sitting (say overnight), it doesn't make any sound and runs smoothly. After it warms up, the sound starts occuring, but only at slow speeds and sharp turns.
If I'm not moving at all, I only have to turn the steering wheel back and forth and inch and it makes the noise. I do have a small leak, but I can go a whole year without adding any power steering fluid (and only a little at that).
I don't have any deadspots or loss of power.
Is this the gears binding? I plan on doing a front end rebuild, could bad tie rods/ball joints/bushings cause this problem.
Thanks,
Joe
Old May 24, 2006 | 09:32 PM
86_RedRider
Cruise-In V Veteran
ttt
Old Jul 31, 2023 | 03:43 PM
TLJ86C4's Avatar
TLJ86C4
Bump.
experiencing the same issue. Any suggestions
Old Aug 1, 2023 | 07:15 AM
2011KLR's Avatar
2011KLR
Id suggest getring the front wheels off the ground and have someone turn the steering lock to lock while you watch and touch the moving parts. (engine off of course)
Old Aug 1, 2023 | 08:20 AM
Whaleman's Avatar
Whaleman
Before posting ,I assume, you raised both front wheels off the ground and checked everything for tightness, Tie rod ends (both inner and outer), wheel bearings and ball joints. With the wheels off the ground start the engine and try to get the sound with someone looking up front. Should be easy to locate. Dan
Old Aug 1, 2023 | 10:26 AM
TLJ86C4's Avatar
TLJ86C4
I had the ball joints & front end inspected a month ago, and I was told it was “fine”. Not sure if they checked when the car was actually up to temperature & making the particular grinding / cracking noise..
I don’t have Jack stands available to me at the moment…
Old Aug 1, 2023 | 10:44 AM
Talfryyn's Avatar
Talfryyn
With the car on the ground and not running, roll down the drivers window and open the hood. Reach in and turn the wheel back and forth while observing the front tire. Look for lost motion. i.e. the steering has a noticeable dead spot.
Worst case scenario there is a fractured ball in the steering rack ball nut. It would bind or pop when that ball is on the ball screw. Ball fractures can happen when the nut/screw are worn out. So if you have lost motion and it's not the tie rod ends or ball joints the steering rack is suspect.
If it is the rack, and I'm saying it has to be that, replace it sooner than later as the next failure modes are worse.
Old Aug 2, 2023 | 10:59 AM
TLJ86C4's Avatar
TLJ86C4
I can confirm no loss of motion or dead spots when turning the wheel. A mechanic told me it could be lack of grease at the ball joints…I’ll try to get a grease gun today to start juicing up those joints.
Old Aug 3, 2023 | 08:05 AM
Whaleman's Avatar
Whaleman
I would think ball joints would have to be dry as a bone to bind and make a noise when turning. Dan
Old Aug 3, 2023 | 08:57 AM
Vets-Vet's Avatar
Vets-Vet
Could it be the transverse spring pockets on the LCA's are dry ?
Old Aug 3, 2023 | 10:44 AM
TLJ86C4's Avatar
TLJ86C4
What’s the best way (sharing site?) where I can upload a video of the noise to share with you?
Old Aug 3, 2023 | 10:46 AM
Vets-Vet's Avatar
Vets-Vet
this site will except the following files.
apk avi bin bmp cfg csv doc docx ecu efi gif gsc hex hpl hpt html jpe jpeg jpg mov mp3 mpeg mpg msl msq pdf png pps psd rar table tun txt vex wav wmf wmv xls xlsx xml zip
If you can get the audio into a wav file it will also work.
Old Aug 3, 2023 | 12:57 PM
TLJ86C4's Avatar
TLJ86C4
Hers is a sample of the sound I’m experiencing when turning the steering wheel
File Type: mov
Old Aug 3, 2023 | 02:22 PM
TLJ86C4's Avatar
TLJ86C4
FYI, it appears the doorknobs that checked my
ball joints didn’t realize that the passenger side lower ball joint has a ripped boot…which could be the answer to this mystery, as I assume the joint is dry & dirty now.
Old Aug 8, 2023 | 12:25 PM
TLJ86C4's Avatar
TLJ86C4
Changing out the worn ball joint today, however the mechanic seems to think the creaking noise may be coming from the rack itself….possibly the bushings…Does that sound right?
Old Aug 8, 2023 | 12:50 PM
Whaleman's Avatar
Whaleman
If that is a ball joint you would have to think you could temporarily tape up the ball joint ripped seal and pump the crap out of it while turning and get some level of relief on the noise. Dan
Old Aug 8, 2023 | 02:11 PM
TLJ86C4's Avatar
TLJ86C4
I might have to tape the old ball joint, as the new MOOG replacement lower ball joint doesn’t fit according to the mechanic. I was told that it fits loose. As anyone experienced this before? I have two (model #K6345) and both didn’t work. Ordered from ROCKAUTO…very unusual
To Cracking Sound from Steering Rack
Old Aug 8, 2023 | 06:22 PM
SouthernSon's Avatar
SouthernSon
Mine was. Sent it to Turn One and problem solved. I had a Cardone rack stuck in my LT4 but didn't like the ratio since my '96 was a little quicker ratio from factory. Glad I removed that replacement and sent the original to T1 for rebuild. Excellent work and no creaking/cracking sound when turning.
Old Aug 8, 2023 | 09:34 PM
Went's Avatar
Went
I also used Turn One for my rack rebuild. X2 excellent work from them.
Old Aug 9, 2023 | 09:22 AM
TLJ86C4's Avatar
TLJ86C4
It appears that tightening some loose bolts around the rack remedied the problem, very unusual, but not unheard of. I’m now more confused about the loose fitting moog lower ball joint. I haven’t come across a thread that mentions any sizing issues with that particular brand…
