Clunking noise when driving
Old May 24, 2006 | 02:44 PM
spencerwilliams1's Avatar
spencerwilliams1
3rd Gear
Default Clunking noise when driving
I have a 1984 with 78K miles. While driving I heard a loud bang, and then a loud clunking noise from under the rear of the corvette. The noise only continues when driving, so I had it put on a flat bed and towed home. I removed both rear tires and don't see anything obvious. I put the car in neutral and turned the rear wheels and hear a slight click. This leads me to believe there might be a bad yoke or something to do with torque converter???
Any suggestions.
thanks!
Old May 24, 2006 | 02:49 PM
RRT vette's Avatar
RRT vette
If it's coming from the rear it sounds like a tooth is broke off in the rear end. Just a guess.
Old May 24, 2006 | 04:41 PM
spencerwilliams1
3rd Gear
Thank you for the comment.
I thought of the rear end at first, but that noise is really loud. I put it on stands and put it in drive and it make the same loud noise. I was thinking that a noise in the rear end would be more muffled.
I probably should have a second person listen to it, or get it on the lift.
To Clunking noise when driving
