Replacing injectors ??
Old May 24, 2006 | 03:25 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Replacing injectors ??
Does anybody have any tips for replacing FI's on LT1?
Do I need any other gaskets,seals besides what I get w/FI's?
About how long does it take?
TIA
PS - What size injectors were used in a 93?
Autozone has GP Sorenson, are these any good?
If not, then what are good ones?
Old May 24, 2006 | 04:01 PM
93 ragtop's Avatar
93 ragtop
The factory injector is rated at 23.8lbs but that is at 43.5 lbs pressure. So if you install a injector such as the ford svo injectors, check what pressure they are rated at. For example a 24lb injector from ford rated at 38-39 lbs will flow more then 24 lbs when running at 43.5 lbs pressure
Old May 24, 2006 | 04:46 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Thanks 93
To Replacing injectors ??
