Engine almost in...Any start up advice???
Old Aug 25, 2001 | 10:27 PM
FoolCrzy's Avatar
FoolCrzy
Default Engine almost in...Any start up advice???
The new engine is in(see sig). :D I put it in today. Now I have a couple days of accessory/vacuum line/TPI runner/wiring installation. Does anyone have any first start -up suggestions? I plan on #1 firing position, line up distributor, Prime Fuel/oil/check pressure. CRANK! Sound good?
[Modified by FoolCrzy, 8:28 PM 8/25/2001]
Old Aug 25, 2001 | 10:32 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Engine almost in...Any start up advice??? (FoolCrzy)
When you think you've primed the oil system enough still do it some more. Also rotate the crank while do this, you can do it to much.
Old Aug 25, 2001 | 10:50 PM
FoolCrzy's Avatar
FoolCrzy
Default Re: Engine almost in...Any start up advice??? (mackeyred96)
Thanks for the tip. probably happening wednesday.
Old Aug 25, 2001 | 11:01 PM
C4RAG's Avatar
C4RAG
When you start it first time, run it in for 5 minutes at 2000 rpm... No synthetic oil first 2000-3000 miles... Have a friend standby and watch for fuel leaks... Tighten headers/manifolds at 500 miles or at any sign of leaks... Be prepared for glitches first 1000 miles...
Old Aug 26, 2001 | 05:09 AM
ol,RJ's Avatar
ol,RJ
ditto to everything above. plus:
leave the distributor just loose enough that you can rotate it with some effort. but not very loose. or have a distributor wrench handy. that way if you need to change the timing a little you can. (counter clockwise= advance timing).
have extra coolant handy.
have a fire extenguiser handy ( just incase ). :eek:
make sure the battery is fully charged before hand.
change the oil and filter after the first start up to remove the assembly fluid or at the very least change the filter.
for all oil changes: fill the filter with oil before putting it on.. that way it dosn't have to wait for the oil pump to fill it when you restart it.....
good luck :cool:
Old Aug 26, 2001 | 08:13 AM
FoolCrzy's Avatar
FoolCrzy
Default Re: Engine almost in...Any start up advice??? (ol,RJ)
Awesome! thanks guys! :cheers:
To Engine almost in...Any start up advice???
