water pump replacement
Old May 25, 2006 | 01:46 AM
Dave-B's Avatar
Dave-B
Default water pump replacement
On my 86, is changing the water pump a big deal, or or not???
Old May 25, 2006 | 02:06 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Default Big Deal?
It depends on what you call a "big deal". It's probably harder to change the plugs than it is to change the water pump. Anything less than changing out the engine isn't a "big deal" in my opinion!
S.T.W.
Old May 25, 2006 | 08:28 AM
Sam Lam's Avatar
Sam Lam
Be prepared to spend a few hours just to get the old pump out. This is due to the pump location and the parts that must be removed just to get to the pump (on my 89). Consider doing at TB bypass if you have not done this on your car.
Old May 25, 2006 | 01:38 PM
mikey whipreck's Avatar
mikey whipreck
The bolts were seized up on my old water pump. It took more time getting those off then the entire rest of the procedure.
That was a religious experience to get those freaking things off.
Old May 25, 2006 | 02:56 PM
Dave-B's Avatar
Dave-B
S.T.W.
I've allready changed the plugs and wires-----so I guess the pump won't be to bad as long as the bolts come free. Any leads on what pump to put back on???? Will it make any difference if there alu. heads??? Thanks for your come-back. Dave
Old May 25, 2006 | 03:04 PM
Sam Lam's Avatar
Sam Lam
Dave: I always use anti-sieze lubricant when placing steel bolts into aluminum (and steel too). You can get this stuff from NAPA and it is good. A bit messy if you do not control its application!!! Take your time on this project and make sure you clean up the threads on your bolts and threaded holes! Suggest you drill two small holes in thermostat to allow air to escape as you refill coolant system. Let me know if you want photos of how to do this.
PS: I replaced my original pump with a Delco. Buy a good replacement and do not bottom fish on the price!
Old May 25, 2006 | 07:00 PM
Dave-B's Avatar
Dave-B
Thanks Sam Lam----------I'll let ya know how everything turns out after the holidays. All I have to do at this point is figure out what else is holding the compresser on that I can't see, and I'll be at the pump!! thanks again--------
Old May 25, 2006 | 09:46 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It's kinda a pain in the azz, a good size job for a beginning wrencher.
After you pull all the smog/a.i.r. valve crap off...
Remove the a/c accumulator bracket, and just unbolt the entire compressor bracket from the motor and slide it over the waterpump studs and out of the way. You do not need to remove the valve cover or the compressor itself. There's one tricky bracket bolt under the pulley that is partially blocked. It has a hex head for an open end wrench and a T40 torx head on it (easier to use), and has a notch in the head as well. You should undo this bolt last, turn it and the compressor clutch to the right location so you can slide it out.
There are two nuts, and about 3 or 4 bolts holding the compressor bracket on.
Old May 26, 2006 | 06:29 PM
Dave-B's Avatar
Dave-B
When I unscrewed the fuel lines, drivers side was fine. Unscrewed the pass side and gas started dribbing out. Well 8 shop towels later I screwed the line back in. Why won't the gas stop running out of the line??? Battery is disconected, but the car is full of gas??? Should I just let it run some more? Dave
Old May 26, 2006 | 07:22 PM
CentralCoaster
Remove the gas cap, and depressurize the fuel at the schrader valve.
Old May 26, 2006 | 11:10 PM
Dave-B's Avatar
Dave-B
Did both of those things C.C.----Gas kept coming out of the one line. Took a rubber vacume cap and stuck it over the line. The gas was coming out of the end of the line from the tank. As far as I know, I'm to the pump, and ready to take it off. All the bolts on the pump broke loose. Thanks again. Dave
Old May 27, 2006 | 01:34 AM
steve1ph2's Avatar
steve1ph2
i think its kinda of beotch cause on my `90 every single bracket for the entire front of the motor seems to be bolted to the water pump which have to be removed first. if you want an exploded view and rr for this job i can send you a pdf with diagrams and instructions.
Old May 29, 2006 | 11:30 PM
Sam Lam's Avatar
Sam Lam
Dave: Is the vehicle on a level surface? If the car is on slope, the gas tank may be higher than the end of the fuel line. This will cause the gas to drain at the front of the engine. Just a thought. When I removed the water pump on my 89, I found it easier to raise the car on jack stands and remove both front wheels. Having the front wheels off and elevated makes better access to the water pump. Hope this is helpful.
To water pump replacement
