4+3 Shifter Re-Build?
Old May 25, 2006 | 11:39 AM
CAJUN C4's Avatar
CAJUN C4
Default 4+3 Shifter Re-Build?
Anyone know of anyone that re-builds the 4+3 shifters???
Thanx
Old May 26, 2006 | 02:22 PM
mrc24x's Avatar
mrc24x
I disassembled mine and cleaned everthing up with a wire wheel and greased each of the pieces before putting it back together. Also my reverse lockout was missing so I cut a 1/8" diameter SS rod to the right length and bent the top 1/4" over 90 degrees then slid it into the original place for the lockout rod and it works great. Best mod for my car yet. Pretty straight forward once you see how it is put together. Good luck
Old May 26, 2006 | 02:33 PM
CAJUN C4's Avatar
CAJUN C4
A couple years ago mine got stuck in reverse.Couldn't get it out for anything.I bought a used shifter installed it works great.I wonder if my reverse lock out pin got messed up?
I'm gonna have to take it apart.
Old May 26, 2006 | 02:49 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
A messed up reverse lockout will keep you out of reverse, but can't keep you stuck in it.
There is an ignition interlock though, that would keep you stuck in Reverse.
There's nothing to these really. Just disassemble and clean, and take up slack with a shim or a new spring loaded e-clip.
Adjust the neutral alignment very carefully, and it'll be good as new.
Old May 26, 2006 | 03:11 PM
CAJUN C4's Avatar
CAJUN C4
I guess your right I'll do that and see if I can see any reason why it locked in reverse? My new one worked (s) fine.
I'll clean & grease and take up the slack.
Thanx Guys
To 4+3 Shifter Re-Build?
