Heater Core
Old May 26, 2006 | 04:05 AM
Ruff Rider's Avatar
Ruff Rider
Default Heater Core
Alot of times when i start my car the windshield fogs over...is this a sign that my heater core is going out ????
Old May 26, 2006 | 05:22 AM
86PACER's Avatar
86PACER
I sometimes get that but only at night.
Old May 26, 2006 | 07:49 AM
Achilleus07's Avatar
Achilleus07
I've been getting that alot lately when using the air conditioning system. If I run into the store and then run back out to my car and start it up...even if the air is off it kicks out hot air and fogs up the front window. I think thats normal. Maybe someone else will have a technical answer though. I wouldnt worry about it.
Old May 26, 2006 | 08:02 AM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
Active Streak: 90 Days
St. Jude Donor '08 thru '26
I think it could be one of two things, the heater core is starting to leak or there is a condensate drain from the evap box that could be clogged. I don't know where the drain is or what it looks like because I have not looked in the Helm for it....just the thought of going near that stuff on a C4 gives me the !
I have had that situation go either way for me. My 72/C3 did the fog thing and it turned out to be the heater core. My 93 Tempo did the fog thing and it was the drain that was clogged.
Old May 26, 2006 | 08:17 AM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
On a muggy day, the AC can condense moisture from the air onto the the windshield (usually on the outside), but the heater core will mist coolant onto the inside of the windshield. If it is cool outside and you are in heat mode, the mist is on the inside and it persists ..... and it smells fishy at all, then it is probably the core. Also, if it's the core, it is more likely to do this when the engine is warmed up. It doesn't sound like what you've got.
Old May 26, 2006 | 08:29 AM
pcolt94's Avatar
pcolt94
Sounds pretty normal to me to, I get the same effects. Usually when the core is bad you know it. Wet rugs and that unique smell.
Old May 26, 2006 | 09:33 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Yeah both mine (87 and 94) always did that if the conditions were right for it, never thought twice about it. Its just somthing ive always excepted.
Old May 26, 2006 | 09:39 AM
Aardwolf's Avatar
Aardwolf
Does any of your weatherstrip leak? If it's not A/C or core related, there could just be some moisture in the cabin from a car wash, rain, etc.
Old May 26, 2006 | 11:49 AM
SunCr's Avatar
SunCr
GM and most of the OEM's actually have a built in purge or delay a/c function that is to direct the air through the heater vents at start up so that any moisture laden air is directed to the floor and not onto the windshield. It doesn't always work as advertised - usually because it's only for a second or two and high humiditys set the stage for quite a bit of moisture. Do make sure that the weep hole in the evaporator case is open - though when it's completely blocked up, you usually end up with a stream of water out of the heater vents. It's about an 1/8 of an inch in diameter on the bottom of the case. Feel around until you find it or jackup the right side. Use a toothpick or other soft object (I wouldn't poke a screwdriver or metal clothes hanger in there and risk puncturing the Evaporator) to free any obstruction.
Old May 26, 2006 | 12:03 PM
Casethecorvetteman
Mine is all upside down so it fits on the left hand side of the car. I hope they drilled a new hole!!!
Old May 26, 2006 | 03:25 PM
Ruff Rider's Avatar
Ruff Rider
Thanks for all the info, and yes I do need to replace (looks like most) the weather-striping... Who ever had it before me must have just let it sit out in the desert sun, paint faided also but motor strong ....Thanks for replys fellow vetters
P.S. No, there is no fishy smell..
Old May 26, 2006 | 04:06 PM
ceberus's Avatar
ceberus
I think that is normal behavior with climate control systems. If you don't smell antifreeze, I would not worry about it.
To Heater Core
