Cooling fan comes on when retrieving codes!?!?!?
Old May 27, 2006 | 05:26 PM
VtVette's Avatar
VtVette
Default Cooling fan comes on when retrieving codes!?!?!?
I was diagnosing an issue where my cooling fan comes on whenever the engine is running. Not when the ignition is on, only when the engine is running. I figured I would check the ECU for codes so I jumped the terminals in the ALDL connector with the paper clip. When I turned on the ignition with the paper clip in place the cooling fan came on. I do not know enough about the diagnostic mode of the ECU to know what this means. Can someone elaborate for me?
thanks,
Old May 27, 2006 | 05:35 PM
aboatguy's Avatar
aboatguy
When I retrieve codes or program my ECM the fans come cycle on for a second or two.
Mike
Old May 27, 2006 | 05:46 PM
VtVette's Avatar
VtVette
I've never seen this happen before. The main fan was on the whole time I was retreiving codes. I've got to believe this has to do with my fan being on whenever the engine is running.
Old May 27, 2006 | 05:49 PM
CFI-EFI's Avatar
CFI-EFI
It is supposed to. The IAC will also close, and most solenoids and relays will be activated in the diagnostic mode. You won't find any codes that will lead to the diagnosis of that fan problem. Do you have an auxiliary fan? The 1985 without an aux fan uses unique circuitry. Your problem may be the result of your cross breeding the car and the wiring harness.
RACE ON!!!
Old May 27, 2006 | 06:05 PM
VtVette's Avatar
VtVette
RACE ON!!!
Thanks for the info CFI. The car had an aux fan, and the '86 harness has all the wiring for the aux fan.
The cooling fan circuit is pretty basic, and it's been covered here on the forum before. Unfortunatley my '86 manual does not have the diagnostic flow charts, it's a white cover edition. I do have the wiring diagrams though. I'm sure I will figure out what is triggering the relay. I was just startled when the cooling fan came on. I wanted to make sure this was not some sign of a faulty ECU.
thanks guys,
Old May 27, 2006 | 06:21 PM
RRT vette's Avatar
RRT vette
RACE ON!!!
My fan on my 86 comes on and stays on the whole time I run the ECM diagnositic check. Normal, I would assume.
Old May 27, 2006 | 06:44 PM
Steel Breeze's Avatar
Steel Breeze
What He said...
Old May 27, 2006 | 08:55 PM
CFI-EFI's Avatar
CFI-EFI
I don't know that any FSM has a trouble shooting chart for the fan(s). As you stated, it is a pretty basic relay powered system. Since your 1985 came with the aux fan, the 1986 harness for an aux fan should work just fine. The ECM causes the primary circuit of the relay to close when the ECT sensor signals the ECM that the engine has reached the temp programmed into the prom for fan activation, or the A/C pressure switch indicates to the ECM that the A/C is on. A bare wire in circuit# 335 could cause a ground that would close the relay and cause the fan to run.
RACE ON!!!
To Cooling fan comes on when retrieving codes!?!?!?
