Need LT1 (92-93) BINS.
Old May 27, 2006 | 08:44 PM
MrNuke's Avatar
MrNuke
Default Need LT1 (92-93) BINS.
I don't want to take apart my stock memcal, and would like to see the stock LT1 BIN. Anyone have one read I could have?
Thanks guys..
Old May 28, 2006 | 03:05 PM
carriljc's Avatar
carriljc
Default Search the following websites:
Enter the desired search item below, and use the "go" button...(don't push enter, it doesn't appear to work).
http://www.efitune.com/broadcast_codes/
You can also search below. The ECM/PCM for the 92-93 was 16159278.
http://www.moates.net/fileman/index....ock%20Binaries
If you provide us the broadcast code from the MEMCAL, we can narrow it down for you.
Old May 28, 2006 | 03:28 PM
tjwong's Avatar
tjwong
Thanks guys..
Gabe you need one of these to read your chip while its in the memcal:
http://www.thirdgen.org/tech/images/prom/1138122.jpg
http://www.thirdgen.org/tech/images/prom/1138132.jpg
http://www.thirdgen.org/tech/images/prom/1138128.jpg
http://www.thirdgen.org/tech/images/prom/1138134.jpg
You can buy this do-dad from:
Source: Digi-Key
PN: CHW34G-ND
Price: $4.46
http://www.digikey.com/
Old May 28, 2006 | 03:38 PM
carriljc's Avatar
carriljc
Default I have the HDR-1 from Moates...
it looks like this...I just used it to read a friend's LT1 bin this weekend. I use an Autoprom
http://www.moates.net/documentation....entation_id=12
Old May 28, 2006 | 04:08 PM
tjwong's Avatar
tjwong
Thats a lot nicer and cleaner than using a hacked up header that I used from Digi-key. But mine was half the cost
Old May 28, 2006 | 04:30 PM
carriljc's Avatar
carriljc
Default I figured I'd splurge and...
blow the Ten bucks.....and I didn't know about the digikey option. Dammit Jim! I try to be a bargain hunter..
Works great though.....
Old May 28, 2006 | 09:45 PM
MrNuke's Avatar
MrNuke
Thanks guys, got the bin I needed..
To Need LT1 (92-93) BINS.
