Engine runs rough until @ 200*?? Opinions
Old May 28, 2006 | 07:33 PM
vetterlatethannever's Avatar
vetterlatethannever
Default Engine runs rough until @ 200*?? Opinions
A buddy of mine has a 92 C4 that almost seems to be missing when it is cold. It runs very rough (almost like a it has a good size cam in it) until it reaches around 198 degrees (most of the time this temp. will be the point it starts running smooth.) He has done plugs and wires and is thinking that it is the opti causing this, anyone here have any suggestions I could run at him?
Old May 28, 2006 | 09:17 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Factory Service Manual by Helm,Inc. to determine actual procedure to systematically eliminate potential problem areas/parts? May actually be cheaper than replacing parts only to find that the problem is still there.
Old May 29, 2006 | 02:28 AM
vetterlatethannever
Old May 29, 2006 | 11:08 AM
JBB's Avatar
JBB
I would look at vacuum leaks. A hot engine can stand lean much better than a cold one. Add propane when cold idling & see if it smoothes out.
(Go to a vacuum line, like the PCV. Whatever you do, don't run it through the MAF!)
To Engine runs rough until @ 200*?? Opinions
