Need $32 xdf file
Old May 28, 2006 | 01:15 AM
severe-1's Avatar
severe-1
Default Need $32 xdf file
I am trying to read my chip using Tunerpro. I have downloaded the bin,
but I only have the 6e xdf file.
Where can i find mask (definition) files? I have found thousands of bin files, but of coarse, no xdf files.
I have a three day weekend and would like to atleast get started tuning....
I am starting with a TPIS chip. I think i read somewhere that they use some special code that can't me modified. Any input?
Should I just start from scratch with a ARAP 6e and disco my cold start??
Car runs good except lean at idle/slow cruise. Also hesitation off idle and knock at 3500-3800 wot.
Thanks for any help or input...
Old May 28, 2006 | 09:09 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Have a look here mate:
http://www.tunercat.com/tnr_desc/ecm_sup.html
They have the one you need right there
Old May 28, 2006 | 02:58 PM
carriljc's Avatar
carriljc
Default Here you go, from Tunerpro....
http://tunerpro.markmansur.com/downloadBinDefs.htm
Not sure which one you want, but here are the two $32's that I see:
$32 1227165 32.ecu 1227165_160.ads 86 5.0/5.7 F & Y Body
$32B 1227165 32Bv001.ecu 1227165_160.ads 87-88 5.0/5.7 F & Y Body
You can convert the ECU files to XDF files with TunerproRT...
Old May 28, 2006 | 08:27 PM
severe-1's Avatar
severe-1
Ask and though shall receive...
Old May 28, 2006 | 08:29 PM
severe-1's Avatar
severe-1
This I did not know...Thanks for the good info...
Old May 29, 2006 | 09:41 AM
Casethecorvetteman
Not sure which one you want, but here are the two $32's......
Yes, one is for 86, and one is for 87 and 88
Old May 29, 2006 | 11:51 AM
ramiles's Avatar
ramiles
I was doing some research on TGO and saw an article that looked like some people thought the $6 was better than the $32 in terms on items that were "hacked" (and also if you delte the cold start injector). I'm getting ready to tune my '86 - wondered if anyone advocates using the $6 template in place of the $32?
To Need $32 xdf file
