Air Speed Sensor problem? On my 92'
Old May 28, 2006 | 09:44 PM
pletner's Avatar
pletner
Default Air Speed Sensor problem? On my 92'
Hi guys, I'm having engine problems and I need help. My 92 has a surging, inconsistent acceleration at partial throttle. The car runs like a scalded dog at WOT. After checking for vacuum leaks, pulling no error codes and reading other posts, I unplugged my air speed sensor in my intake duct. The car runs fine that way, so I bought a new air speed sensor and the car runs like crap again a partial throttle. What's up!? I have to add that I have new plug wires, plugs,fuel filter, and fuel is at 44psi and holds for 30 mins. after car is shut down.
Old May 28, 2006 | 11:50 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
I believe you are describing the IAT (intake air tempature) sensor. You probably need to run it with a scan tool to see what the computer is reading when it surges.
Old May 29, 2006 | 01:11 AM
pletner's Avatar
pletner
I'm sorry:o You are right. I'll have to try the scan tool, thanks for the reply!
To Air Speed Sensor problem? On my 92'
