'92 LT1 scan problems?
Old May 29, 2006 | 08:19 PM
MrNuke's Avatar
MrNuke
Default '92 LT1 scan problems?
Ok this is really odd.
What happens :
I turn the car to on (but don't start), and when I try TTS Datamaster using a laptop with a real serial port, everything seems good. It stays connected when reading or monitoring mode.
Then I start the engine, and it disconnects and resynchs, and keeps doing this for good. I get maybe a data reading every 10 seconds.
Turn the engien off, everything back to working properly again.
WTH??
This I've tried :
Two other Laptops with USB/SERIAL adaptors, none worked.
Messing with turning FIFO off and or setting different buffer sizes.
Messing with the flow control, baud rate, parity, etc.. on the serial port's settings tab.
Checked grounds, even ran wire from battery negative to cable, no difference.
Disabled Firewire/Infrared, anything I could think of.
The ALDL cable is a home made self-powered one that I used on my '85 with WINALDL,so I know it worked at least..
Freescan doesn't even seem to read anything at all..
I want to read the data on the car so I can do some tuning on it, but am at a loss. Anyone got any ideas?
Old May 30, 2006 | 05:17 PM
MrNuke's Avatar
MrNuke
anyone use datamaster, and have this ever happen?
Old Jun 1, 2006 | 10:43 PM
MrNuke's Avatar
MrNuke
ttt
Old Jun 2, 2006 | 02:02 AM
tjwong's Avatar
tjwong
Gabe, I use a AKM cable and I haven't had any problems reading a early LT1 car. It could be that your cable has that 10k ohm resistor in it for the early MAF cars? If that is so, try removing it.
Old Jun 2, 2006 | 08:33 AM
MrNuke's Avatar
MrNuke
It doesn't.. I remember having to use a 10k ohm resistor to use it on my '85 before. Just odd how it works fine until the engine is started up.. dangit..
Old Jun 2, 2006 | 12:17 PM
Casethecorvetteman's Avatar
Casethecorvetteman
By self powered do you mean running power from the serial port on the computer or power from the cigarette lighter?
Old Jun 2, 2006 | 03:31 PM
MrNuke's Avatar
MrNuke
It is powered from the serial port..
Old Jun 2, 2006 | 10:49 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
10KOHM resistor?WIll this affect a 93LT1with speed density?
Old Jun 3, 2006 | 09:08 AM
Casethecorvetteman
Have you tried powering it from the cigarette lighter?
Old Jun 3, 2006 | 10:31 AM
tjwong's Avatar
tjwong
Nope this was for the early TPI cars. You should not have to use the resistor with anything newer than 1991. However it may cause a com error if its used with the later cars.
Old Jun 3, 2006 | 11:03 AM
MrNuke's Avatar
MrNuke
I can't it's an enclosed cable from AKM I think.
Old Jun 3, 2006 | 11:46 AM
Casethecorvetteman
Oh ok, well you cant do that then!!
Old Jun 3, 2006 | 11:56 AM
MrNuke's Avatar
MrNuke
I dunno.. It's odd.. Not sure what else to try. maybe get another cable.. lol
Old Jun 3, 2006 | 04:24 PM
steve40th's Avatar
steve40th
Last night I figured mine out. I powered up the laptop. Opened device manager and looked at ports ?(COM and LPT). Then I took the cable from AKM and and plugged it into the laptop. Then the PORTS(COM &LPT) opened up and showed a new device, the AKM cable. But it was labeled as COM 6, so I changed it in its propertys, to COM 3. And voila after that the Datamaster worked great. Simple. But, it wouldnt give me any of these options till I plugged the cbale in.
Also, on the AKM cable , if you are using the serial to USB conversion there is a white dipswitch that needs to be in a position so the fans come on when you plug it into the ALDL with the ignition on.
Hope this helps, Steve
Old Jun 11, 2006 | 09:42 PM
MrNuke's Avatar
MrNuke
I'm beginning to think it is a bad cable or the cable isn't compatible with my '92.. I had a buddy hook his Tech 2 up to the car and all the data was flowing and displaying while the car was running sweetly..
So where is the best and cheapest place to get a cable for my '92 so I can finally datalog it?
I saw the USB ALDL setup from Moates.net, but that's like $80+ for both parts just for the wire. Then the software cost, etc...
Old Jun 19, 2006 | 10:05 AM
MrNuke's Avatar
MrNuke
ttt
Old Jun 21, 2006 | 09:43 PM
Balanced 89's Avatar
Balanced 89
Try ALDLCABLES.com I think they are about $40 and will work with many of the free ware pkgs like WinALDL.
To '92 LT1 scan problems?
