C6 Rims - Tire size recommendations needed
Old May 30, 2006 | 03:02 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default C6 Rims - Tire size recommendations needed
Hey,
Just ordered a set of 17x9 C6 Chrome rims and now need to order the tires... Need some sizing suggestions.... Thanks
vinnie
Old May 30, 2006 | 03:43 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
While that's a good width on the front, 9" is a little narrow for the rears. If it were mine, I'd put 255/45 on the front and 275/40's on the rear. You could go 275/40's at all four corners.
Larry
code5coupe
Old May 30, 2006 | 03:49 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Yep, I'd suggest the same as Larry. 255/45 and 275/40's
Old May 31, 2006 | 11:29 AM
vinnies87's Avatar
vinnies87
Larry
code5coupe
I know, i would have like to go with larger rim on the rear, but the package price for all 4 was just great.... so if I'm reading you right, there should be no issue with that tire size(s) with my rims (frt & back)
Old May 31, 2006 | 11:54 AM
shakedown067
A 275 tire is the widest recommend width for a 9" wheel. Might as well go with 275's on all four so you can rotate them.
Old May 31, 2006 | 11:56 AM
jrp's Avatar
jrp
Browse tirerack.com for the ones you're interested in. Most, if not all, of the tires will have a spec sheet that will give you the suggested/min/max rim width.
Eagle F1 GS-D3, for example.
Old May 31, 2006 | 02:08 PM
Blackhole's Avatar
Blackhole
Are you going to use spacers since the C6 wheel offset is not correct for the 84 to 87 models? They will sit inboard about 3/4 inch. (56mm less 38mm) could affect you tire choice.
Old May 31, 2006 | 03:45 PM
vinnies87's Avatar
vinnies87
The rims are 38mm so direct fit.
Old May 31, 2006 | 06:00 PM
Wildcat1's Avatar
Wildcat1
I used to have 255s up front, the car is much much more fun now with wider tires up front. Get as wide as you can...i.e. 275 GS-D3s.
Old Jun 1, 2006 | 12:52 PM
Blackhole's Avatar
Blackhole
Where did you order them from? AFS is about the only place I have been able to find the correct offset and only a molds, would love to have more choices for my 85
To C6 Rims - Tire size recommendations needed
