first post and question about 84 instrument cluster...problems
Old May 30, 2006 | 03:55 PM
kennyw12345's Avatar
kennyw12345
4th Gear
Default first post and question about 84 instrument cluster...problems
Hey guys, this is my first post here.
My father in-law has an 84. The instrument cluster is not working correctly. Lights were randomly flashing but no information was reading correctly.
Upon removing the dash and cluster, I found that someone had already worked on this cluster before. there were wires coming to the cluster that were not supposed to be there. One of them had power to it. so basically someone had "jimmy rigged" the thing. I sent it off for repair. the guy said he repaired it and it works great.
now when I plug it back into the car there are no back lights at all. It looks like the left hand side (speedo) may be working, just not lit up. the right hand side (tach) is not working at all. I believe the guy that he repaired the cluster....so it must be another problem.
Question is: what else could be bad for the cluster not be to working. Is there some kind of instrument cluster sending unit that could have gone bad? or what else should i check?
thanks
Old May 30, 2006 | 04:28 PM
kennyw12345
4th Gear
anyone?
Old May 30, 2006 | 09:59 PM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
Could be the ground connection for the cluster, i belive it is behind the panel down by the drivers foot.
Old May 31, 2006 | 12:10 AM
elkabong's Avatar
elkabong
I agree check the grounds first. Also look at the solder joints. They have a tendency to crack which is another common problem and sometimes hard to find.
Old May 31, 2006 | 12:45 AM
Steel Breeze's Avatar
Steel Breeze
Damn, I hate it when other people get into something ahead of me. Then I have to trouble shoot the problems they added. I used to see that in electronics alot. People bringing in a stereo, all apart in a box. I started turning that stuff down. Somebody has screwed around with your wiring. What a pain in the A- -. If I were there I would help you out, but I'm not, and you'll get it anyway. Good Luck...
Old May 31, 2006 | 01:55 PM
kennyw12345
4th Gear
thanks guys. ill check the ground... so down by the drivers foot?
i think the solder joints should be ok because the guy that repaired it said it works great when he plugs it in.
so there is no kind of sending unit?
Old May 31, 2006 | 05:51 PM
DRAKEFAMILY2
Left foot
Old May 31, 2006 | 06:53 PM
Grenkepr's Avatar
Grenkepr
Seems to me it should have come back to you, repaired. Isn't that what you sent it in for ?
Old Jun 1, 2006 | 10:46 AM
kennyw12345
4th Gear
yes, thats why if think it must be something else...
I even sent it back and he said it works great, thats why im trying to figure out what else to look for...
Old Jun 2, 2006 | 08:57 PM
5pinball's Avatar
5pinball
check connecters that plug into display for bent or missing pins gently pull on wires leading into conecters some may not be conected but look good and if all that checks try spraying with pbblaster let dry before putting juice to circuit with out seeing it thats all i can suggest good luck
To first post and question about 84 instrument cluster...problems
