LT1 Bottom end is being rebuilt (forged rotating assy), we're planning on 10:1 compression ratio. *edit* Displacement will be 383ci.
The motor (before the rebuild) made about 450 CHP. It's a road race ONLY car, but I run 93 / 94 octane pump gas sometimes. Should I stick with 10:1 or can I go a little higher without detonation issues or the possibility of engine damage? A little more power never hurts...
I'm running roughly 11.5:1 on 91 octane gas with no issues at all. A lot of it really depends on how well the combustion chambers in the heads are done. If they are stock I wouldn't go much above 10.8:1
i've got my engine rebuilt/modified, and the measurements have it calculated right 10.2:1. the factory setup was rated at 10.25:1. i run 89 octane with no problems. datamaster recording over 20 min. spans have showed about 6-8 knock counts total -- and this only ocurred while shifting which is perfectly normal. no timing retard.
if you're 10.1:1 c/r and your quench is in the .045-.055" area that's pretty decent so you shouldn't have anything to worry about.....in my humble, dumbassed opinion.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Funny, but that's hardly the case! And yes, quench will become your friend in this quest. In my newest combination, it looks like I'm ending up right around .040" quench with the zero deck. This is considered the practical maximum although some squeeze it even tighter.
i should have posted .035" - .055" (factory crap can get up to .060"+). sorry for the misinformation. and yes i know quench is not only your best friend, but uber-important in the overall setup.
Hi there,
I had puzzled over this as part of my re-build. There is a dynamic compression ratio that you should calculate, the calcuators are on line, I think KB / Silvolite had a really nice one.
The DCR takes into account your cam -- more duration helps you in that you can run more compression.
I had a mild cam (214/224) and thin head gaskets (.029) plus low quench since he decked the block (?0.050?) and with all this I was at a static CR of like 11.2 or so. The LT ran fine on '93 with that.
The LT is a little more forgiving than the gen I small block since you have reverse cooling--cooler heads.
I would be conservative if I were you since road racing makes the motor live in the hot range. If you were to build a motor with too much compression, it might be fine up until say 230 deg. oil temp and then start to knock.
So does this mean that you aren't running your 350 at all after all that work? What happened? I know it was a junkyard block but...
Camshaft overlap can be a make or break issue depending on what you have going on. Also, rod length and the amount of time the piston spends at TDC. You can detonate a 10 to 1 engine or you can buzz an engine near 12 to 1 depending on your combination and get away with pump gas. Something many overlook is at what RPM you load the engine and your timing advance curve...I have seen engines ping down low in the RPM band under a heavy load yet wake up and make killer power on pump gas once the rpm's are mid range and higher. There are lots of factors to consider.
