Idle Air Motor Problem.
Old May 30, 2006 | 07:10 PM
rdcamero's Avatar
rdcamero
Default Idle Air Motor Problem.
Hi I have been having some problems with the idle going up and down when sitting at a stop light.I put the scanner on it today.The idle air counts would be around 7 or 8 when it was idleing right.When the idle would speed up it would read any where from 55 to 75.I have cleaned the motor and the air ways.I also tried to reset it and it still does the same thing.Could anything else be causing this or does it just sound like a bad idle air motor.It has also stalled a few times when stopping also.
Thanks.
Old May 30, 2006 | 07:17 PM
CFI-EFI's Avatar
CFI-EFI
The IAC does as it is told. The fact that the counts are changing, proves that it works. Now you have to track down why the ECM is overworking it. My best, first guess, is a vacuum leak somewhere changing the demand for air to maintain a smooth steady idle.
RACE ON!!!
Old May 31, 2006 | 06:59 AM
pcolt94's Avatar
pcolt94
If you should find no vacume leak or anything obvious, my experience with those kinds of problems has been to change the motor (IAC). Our Firebird got 3 motors in about 10 years and the 98 Jeep got 1 so far. Sometimes cleaning works but seems not to last long for me.
Old May 31, 2006 | 08:03 AM
anesthes's Avatar
anesthes
If his iac counts went up to the moon with no idle change, i'd blame the stepper motor.
His problem is something else.. Map readings might indicate what exactly. Prob a vac leak as suggested.
-- Joe
Old May 31, 2006 | 10:29 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I'd look for a vac leak or dirty TB, too.
Old May 31, 2006 | 11:57 AM
RRT vette's Avatar
RRT vette
my vote is on vacuum leak. When the car idles down do you hear a hissing noise?
Old May 31, 2006 | 12:23 PM
rdcamero's Avatar
rdcamero
I can't really hear any hissing sounds.I will go over all of the hoses good and see if I can find any leaks.The map readings range from 1.39 volts to 1.45 volts at idle and when it speeds up.TPS volts stays right at .58 volts.
Thanks.
Old May 31, 2006 | 07:39 PM
CFI-EFI's Avatar
CFI-EFI
The change in MAP volts indicates a pressure change in the manifold, as might be caused by an intermittent vacuum leak. The steady TPS voltage only indicates that no one is playing with the throttle.
RACE ON!!!
Old Jun 12, 2006 | 06:53 PM
rdcamero's Avatar
rdcamero
I have not been able to find any vacume leaks yet.This only starts to happen after the car has been run for a while.I still don't see why the ecm thinks it need to open the iac up more.The car is idleing fine until the iac opens up.I would think a vacume leak would make it try to close off the air not open up to let in more.I also noticed that when trying to merge on to the interstate with the ac on it starks to jerk and jump and kind of spit when its under a hard load.It will run 75-80 with no problems at all.I think my idle problem my be related to this problem as well but I am not sure.
Thanks.
Old Jun 12, 2006 | 08:11 PM
RRT vette's Avatar
RRT vette
The IAC starts working as soon a the engine starts. A vacuum leak is unmeasured air that enters the intake that the ECM can't correct for. You might want to take the throttle body off and take the IAC out for a good cleaning. I consider this a maintenance item. When installing the IAC back into the TB, make sure the tip of the pintle is no further than 1 1/8" from the IAC flange. A new set of gaskets probably wouldn't hurt either.
Old Jun 13, 2006 | 03:01 PM
rdcamero's Avatar
rdcamero
Hi I noticed today that when I have the ac on it seems to idle fine.I know that will cause the iac to raise the idle some.It seems to idle smooth with no surging up and down.The whole engine just feels smoother with the ac on.I also though the 91 Z28 I had felt smoother with the ac on as well.Maybe it is just me.Anyone else think this.
To Idle Air Motor Problem.
