'90 Speedometer Intermittent
Old May 31, 2006 | 04:14 PM
rmendoza's Avatar
rmendoza
Default '90 Speedometer Intermittent
Recently bought '90 and everything worked fine. After about 3 months noticed the speedometer stayed at 0 as I was accelerating, then would catch on and run up to 25 then back to 0 a time or two then catch up to 35 (which was the right speed) and be ok.
It has gotten progressively worst and now stays at 0. Ocassionally when on the freeway doing 70, it will move off of 0 an run back and forth between 0 & what ever speed I'm going. Sometimes settling out at the correct speed and sometimes just going back and staying at 0.
I would like to fix or get it fixed, any idea?
thx
rick mendoza
Old May 31, 2006 | 05:25 PM
Red Tornado's Avatar
Red Tornado
you have what is most likely a bad tachometer filter. its a silver cylinder mounted at the rear of the left cylinder head. i don't believe you'll find a new aftermarket replacement for 90/91. try a salvage yard. thats what i did, and my tach has returned to full functionality. if this doesn't work, then the most likely cause is a bad ground in your instrument cluster. try the tach filter replacement first; a used one will run you about $30 since the part has been discontinued without replacement.
try: www.corvettesalvage.com
Old May 31, 2006 | 09:56 PM
rmendoza's Avatar
rmendoza
Thanks Brad,
I will keep that info about the tach fillter. In fact on one occassion my did fluxuate a little and sometimes when I turn it off, the Tach pegs fully up. If I turn on the key on it will reset to 0, so I'll check that out.
However, my write-up was on my Speedometer. Please reread my write-up as you may also has some helpful hints on my Speedometer issue.
thx again
rick
Old Jun 1, 2006 | 09:04 AM
bad-zr1's Avatar
bad-zr1
Here is a ttt for you Rick. I am also having the identicle problem on a 90 Z and have not found the problem yet.
Will post if I do.
Old Jul 20, 2006 | 02:52 PM
rickbraley's Avatar
rickbraley
Did you ever figure anything out on your intermittent speedometer?
I am having the same problem with my 85. Replaced speed sensor but that did not fix it.
Anything?
Old Jul 20, 2006 | 06:00 PM
rmendoza's Avatar
rmendoza
Default 90 Speedometer Intermittent
No, as a matter of fact it is no longer intermittent, it's inop! 99% of my driving is in town and 45 mph or less and it now stays on 0. Every once in a while when I get on the 405 and drive 70+ for a while it will come on and read correctly, but once the speed drops below 40 it goes to 0 again.
I don't know where the speedometer sensor is (assume the transmission) and I live in an apt, but next week I move and will have a garage. Then perhaps I will be able to address some of the minor irratants that I just don't have the facility to do now.
I assume the problem would be with the transmission, sensor, speedometer and associated wires/connectors/connections.
God Luck and God Bless
rick
Old Jul 20, 2006 | 07:56 PM
eptaylor's Avatar
eptaylor
Default Speedo inop
I just fixed the same problem with mine. My wife is downloading some photos right this minute so when she is done I can show my problem. It was a bad connector that plugs into the transmission sending unit. Also a pic of the filter capacitor.
Old Jul 23, 2006 | 12:59 AM
MaSTeRofDZaSTeR's Avatar
MaSTeRofDZaSTeR
From: "Drive like Hell, you'll get there faster." Tucson AZ
I'm also having the same problem with the speedo on my 90. Its goin crazy after driving for a while showing all sorts of readings until I stop or accelerate at high speeds. Been doin this for the past 2 days. I did just have a new tranny put in about 2 weeks ago so it makes sense.....the whole connector thing. I'm gonna have my tranny ppl check it out. I'll keep everyone posted.
Old Jul 24, 2006 | 08:40 AM
rickbraley's Avatar
rickbraley
eptaylor, will you post your pictures or any other info you have on how you resolved your speedo problem?
thanks.
Old Jul 24, 2006 | 06:15 PM
eptaylor's Avatar
eptaylor
Default Speedo Re-visited
I just installed a new flex-plate and torque converter. Speedo worked goofy afterwards. I pulled the electrical connector to the sending unit on the transmission and it was busted/melted. Replaced connector with a CARQUEST part # S712 for $18.00. Fixed my speedo problem. I should have seen the bad connector in the first place but did not. Included are pics of my UGLY connector. P.S. this is about all I know about speedo problems.
Notice on this pic the plastic tubes that cover the metal prongs are GONE!
Old Jul 24, 2006 | 08:04 PM
Red Tornado
Originally Posted by rmendoza
Thanks Brad,
thx again
rick
Rick, sorry, I was blind and apparently I can't read either. According to my 1990 FSM, section 8A supplement, page 8A-82-17, chart #17, its either the VSS (vehicle speed sensor) or the CCM. Check your cruise control and the radio speed compensated volume control (that means turn it all the way to the right) while driving......do they work? If not, its the VSS (bad connection or bad sensor). If so, then its your CCM (bad connection or bad module).
To '90 Speedometer Intermittent
