Rear wheel vibration problem...
Old May 31, 2006 | 04:31 PM
Cold_B's Avatar
Cold_B
Default Rear wheel vibration problem...
I've got a bad rear passenger wheel vibration problem that just started yesterday night.
Yesterday on my way into work, on the entrance ramp to the highway, I heard something metal hit something else metal under my car. I coasted for a minute, didn't hear anything or feel anything abnormal.
On my home from work, I noticed a real bad vibration in the car thats coming from the rear passenger wheel.
Today, When I first start the car, take off, then stop at the first stop sign/light, the abs go crazy right before I come to a complete stop. The car stops fine, but abs gets really mad and engages for 5 - 10 seconds. After that my Service ABS and Service ASR lights come on and stay on until I turn the car off.
A friend watched my drive in a parking lot, and said that wheel has alot of play in it. The vibrations are really bad, and it seems to have gotten worse since last night.
So far I haven't been able to find a place to take it to, I'm trying to avoid the local stealership and find somewhere that has experience with c4's, but I'm not having any luck right now.
Any ideas what it could be?
Old May 31, 2006 | 04:57 PM
rws.1's Avatar
rws.1
My first thought was a thrown wheel weight which would cause the vibrations and could explain the metal on metal thunk.
But that should not impact your ABS... It is possible that you hit something that damaged a wheel and in the process hit the connector to the ABS sensor....
Old May 31, 2006 | 05:06 PM
Cold_B's Avatar
Cold_B
The vibration is WAY to bad to be a lost wheel weight. The problem deffiently is in the connection of the wheel to the car/suspension.
There was nothing on the road for me to have hit, especially nothing of that size/weight to cause the kind of wheel damage neccesary for the vibration.
I'm thinking its either a u-joint, wheel bearing or a I lost a bolt.
The vibration is bad, the wheel is deffently moving in a way it shouldn't, and it sure is noisy.
Old May 31, 2006 | 05:07 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Sounds like a wheelbearing or u joint issue.
Jack up the wheel in question and see how much it moves around. Could be something in the wheel bearing let go and damaged the ABS sensor.
Let us know what happens.
Old Jun 1, 2006 | 06:39 AM
rons85's Avatar
rons85
I'll guess it's a U-joint issue - when was the last time the u-jont on that side was messed with? Could a cap have come off? You should be able to look up in there with a light and see Something if that's the case...
Old Jun 1, 2006 | 09:29 AM
Cold_B's Avatar
Cold_B
Well, last night I made it home, and jacked the car up, and I think its the wheel hub. This morning I dropped it off at a local car repair place, a good guy I trust and has done other work for me before (non-vette), and explained my problem to him.
Edit: The mechanic just called, said it was my wheel hub, and also a tie rod had alot of play in it. He said the other side isn't looking good, hasn't long for this world, but its not as bad.
To Rear wheel vibration problem...
