valve spring question
Old Jun 1, 2006 | 04:20 PM
MR NICE's Avatar
MR NICE
Default valve spring question
I'm planing on running a 520. lift flat tappet cam, 1.6 roller rockers in my 85 ,my heads are Bow tie cast iron phase 3 #12480034,how can I tell if the heads and springs will work with this lift of cam?The springs look like comp cam hi tec 1.510 dual spring with a damper.Thanks for any help on this
Old Jun 1, 2006 | 06:50 PM
CFI-EFI's Avatar
CFI-EFI
First, determine the lift of the cam. Where did .520" come from? Is it the spec of a cam in an engine with 1.5:1 rocker arms? If so figure YOUR valve lift. Then compress the springs (of one cylinder) to open the valves to YOUR max lift. Then check the spring coils for adequate clearance to prevent coil bind and the spring retainer to valve guide/seal for sufficient clearance.
RACE ON!!!
Old Jun 1, 2006 | 07:27 PM
hip's Avatar
hip
If you are changing cams I would get new springs. I prefer Comp.
Old Jun 1, 2006 | 08:02 PM
MR NICE's Avatar
MR NICE
The lift is 520 with 1.6 ratio rockers,can you give me the formula to figure lift? I'm on a buget or I would spring for new springs,the heads I got used but were gone through.Thanks for the help and advise.
Old Jun 1, 2006 | 09:04 PM
CFI-EFI's Avatar
CFI-EFI
What's to figure? If you know that the lift is 520 with 1.6:1 rockers (that is what you said), and you are using 1.6:1 rockers, what do you want a formula to tell you?
RACE ON!!!
Old Jun 1, 2006 | 09:55 PM
MR NICE's Avatar
MR NICE
.520 is the amount of travel from top of valve stem to the spring pocket or top of head?Would that be correct?Thanks
Old Jun 2, 2006 | 04:22 AM
rodj's Avatar
rodj
.520 is the amount the valve moves from it's closed position (full up ) to it's max open position.
Old Jun 2, 2006 | 11:29 AM
CFI-EFI's Avatar
CFI-EFI
A valve barely longer than 1/2 an inch? YOU said that the lift is .520".
The first 4 words of that sentence answers it's own question. What do you REALLY want to know?
RACE ON!!!
Old Jun 2, 2006 | 12:26 PM
MR NICE's Avatar
MR NICE
I wish I was smart like you,then I would not have to ask arrogant people stupid questions
Old Jun 2, 2006 | 08:12 PM
CFI-EFI's Avatar
CFI-EFI
I'm trying to help. That is why I asked, "What do you REALLY want to know?". The first part of the question provides the answer to the question. ??? From what you have written, I don't understand what it is you are asking. Can you rephrase to tell us what it is you want to know?
RACE ON!!!
To valve spring question
