Vinegar like smell from vents...(A/C on)
Re: Vinegar like smell from vents...(A/C on) (90PoloGreenVette)
Is the light above the button on the A/C flashing? This is an indication of a stored code. Also, check the carpet on the passenger side and make sure it isn't wet at all. Might want to try defrost and see if any moisture appears on the inside of the winshield.
Bob,
The light was flashing before I reset the computer. It hasn't flashed yet this time. I just went out to check on the defroster, zero condensation, just hot air.
Assuming it starts blinking again do you remember how to check for the stored codes?
Joe
[Modified by 90PoloGreenVette, 3:10 PM 8/27/2001]
Joe
Yep, the above post is how you get into diagnostic mode. Let me know if you need more information.
Bob,
Joe
Joe
