Headers are Killing me!!
Old Jun 2, 2006 | 03:49 AM
Epyon127's Avatar
Epyon127
Default Headers are Killing me!!
Alright so I installed a set of EM 1 3/4" Headers to my existing Flowmaster exhaust. I deleted the cats, the AIR, EGR and AC systems. TPIS burned the chip for it. Since I finished the installation I have had nothing but problems. I haven't been able to even take it off the lift!
I have a miss (an audible knocking thumping type of sound like small explosions) coming from the right side exhaust from probably the header or just aft of that. It is intermittent (I have periods where it is constant and periods where it goes away). It also very infrequently backfires out of the exhaust on throttle.
I have checked the spark plugs, spark plug wires and fuel pressure.
What could this be??
I am thinking (hoping) that it is either an exhaust leak or maybe the O2 sensors are not reaching temperature and need to be changed to heated types.
Any help or opinions would be greatly appreciated. Thanks
Old Jun 2, 2006 | 03:56 AM
JoBy's Avatar
JoBy
When you delete cat and AIR you often get 'popping' in the exhaust when you lift the throttle. It also sounds like you have an exhaust leak somewhere on the right side.
Old Jun 2, 2006 | 04:37 AM
SK.LT1's Avatar
SK.LT1
Is it possible that you have a plug wire arcing out against one of the header tubes?
Old Jun 2, 2006 | 04:45 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Are you getting a check engine light?
Injectors can cause poping when the throttle is backed off.
You may need heated O2 sensors.
Old Jun 2, 2006 | 08:08 AM
JackDidley's Avatar
JackDidley
I had this when I changed heads. Wires looked good and did not touch headers. Fire was still jumping to the header at random times. Hard to figure out. Easy fix. Sort of.
Old Jun 2, 2006 | 08:45 AM
MarkBychowski's Avatar
MarkBychowski
Not sure, but I thought '92 already had heated O2 sensors (not sure what year they started using them).
Sounds stupid, but run the car in the dark and look closely at the plug wires. Even though they look fine, sometimes that's the only way to actually see it arcing.
Make sure the O2 sensor on that side wasn't damaged and is seated properly. On my EM's, I had one of the O2's back out because I hadn't torqued it enough. That caused a leak and also caused the sensor to read that there was too much O2, therefore it dumps extra fuel into that bank making it run extremely rich, which gives you symptoms much like you're describing.
Old Jun 2, 2006 | 08:57 AM
quickcat's Avatar
quickcat
92's have unheated O2 sensors.
Epyon127
It sounds to me like you could have an O2 sensor issue. You should scan the computer to see how they are reading before you buy anything. I hope you get to the bottom of it soon, I would like to hear what it turns out to be.
Old Jun 2, 2006 | 09:11 AM
SLOWRIDE's Avatar
SLOWRIDE
Did you use the right gaskets on the Header install. It can run pretty crappy and sound awfull with the wrong ones. Have you checked for leaks. Good Luck
Old Jun 2, 2006 | 09:18 AM
RRT vette's Avatar
RRT vette
Leaks, wires arching with headers, timing off, AIR delete, are a few that wold cause the problem you stated. You will need a heated O2 sensor with headers, if you don't already, because you will stay in open loop more than closed.
Old Jun 2, 2006 | 03:13 PM
Epyon127's Avatar
Epyon127
Thanks for all the help.
I have a Datamaster program, would that be able to see how the O2 sensors are working?
How hard are the heated O2s to wire in?
I will check the wires for arcing tonight in the dark (I never thought of that).
Typically it only seems to backfire when it is on throttle not when letting off. What causes that?
Thanks again!
Old Jun 2, 2006 | 11:50 PM
dave_85's Avatar
dave_85
I would put the old chip in. See how it runs for the first 60 seconds. I don't know when your car goes into closed loop but it should be after about 3 min. If after ~3 min the car starts to run like crap it's the O2 sensors.
Did you change anything else? Did the car run good before the mods?
Old Jun 5, 2006 | 10:54 AM
rickneworleansla's Avatar
rickneworleansla
If I remember correctly my 95 goes into closed loop at 151 degrees according my PCM.
To Headers are Killing me!!
