Tornado, what is it.?????
Old Jun 3, 2006 | 03:06 PM
Ruff Rider's Avatar
Ruff Rider
Default Tornado, what is it.?????
And no i'm not talking about the ones that pick on trailor parks.
I saw a thread reply suggesting a "Tornado" claiming there MPG's went shy high .................
Old Jun 3, 2006 | 03:12 PM
Pete K's Avatar
Pete K
It is a piece of tin that slips in the air intake tube. It is designed to cause the air to create a swirling venturi that makes the inake system more effecient. They claim more power and better milage.
Old Jun 3, 2006 | 03:49 PM
SteveJG's Avatar
SteveJG
I read an article in which Car and Driver tested them. They do absolutly nothing, and in fact make your gas mileage worse because they restrict airflow. I trust Car and Driver.
Old Jun 3, 2006 | 03:53 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
What do a tornado and a redneck divorce have in common?
Either way, someone's fixin' to lose a trailer.....
Old Jun 3, 2006 | 04:53 PM
Ruff Rider's Avatar
Ruff Rider
Sence I was raised in OK i can truly
Old Jun 3, 2006 | 04:59 PM
Ttime's Avatar
Ttime
Old Jun 3, 2006 | 05:20 PM
aboatguy's Avatar
aboatguy
The tornado is as effective as gas tank magnets!
Mike
Old Jun 3, 2006 | 05:39 PM
Ruff Rider's Avatar
Ruff Rider
OK fellow Vetters, I can see that the only good use for the "Tornado" is a Trailer.............
Old Jun 3, 2006 | 06:29 PM
comp's Avatar
comp
Mike
Old Jun 3, 2006 | 07:38 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The guy who said that was joking. The Tornado is a joke. A clever scheme to seperate gullible and uninformed drivers from their money.
Old Jun 3, 2006 | 07:40 PM
Pete K's Avatar
Pete K
For the record, my reply was not to promote it. I simply gave their view. I too agree that it is likely a big waste of money.
CentralCoaster
What do a tornado and a redneck marriage have in common?
There's a lotta sucking and blowing in the beginnng, but after it's all over, you've lost your doublewide and your pickup.
Old Jun 4, 2006 | 12:15 AM
BLACKTALON's Avatar
BLACKTALON
On the infomercial they pick up 25 rwhp.
Old Jun 4, 2006 | 01:19 AM
Klondike's Avatar
Klondike
Default Fancy Proof too
For proof of the "Tornado effect" they taped two 3liter plastic Pepsi jugs together with water filling the bottom one. Then the guy turns it over and the water slowly glug, glugs out of the top one into the bottom, supposedly how your air flows into your stock air tube. Then he turns it upside down again and gives it a swril, "like a tornado", and the water quickly flows from the top jug into the bottom proving the "Tornado effect". We all learned in grade school that the water will only flow into the lower jug, if the air trapped in the lower jug can get past the water into the upper jug. Giving it a "Tornado swirl" opens up the center of the pasage between the two jugs for the air to pass the water now easily flowing down the sides of the jug! OOOH, It's magic
Old Jun 4, 2006 | 02:21 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Corvette Kid: Way too good on that one,,, LMAO....
Old Jun 4, 2006 | 09:49 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
It wont do anything for your VETTE nor pocket. By just reading the installation instructions, it tells you that it will not be able to help nor create .000009 HP. It goes in front of the MAF screen. What a joke.
Old Jun 4, 2006 | 11:05 PM
Snuffy's Avatar
Snuffy
Au contraire. I put one in my Murano and I did get about 1 mpg better mileage. I can't say I got better power but with the price of gas it paid for itself in about 3 months.
To Tornado, what is it.?????
Old Jun 4, 2006 | 11:43 PM
86PACER's Avatar
86PACER
On one of their informercials, there was a guy with his two C4's raving about how much better his vettes performed from this mod. I think the dude got paid to say that.
Old Jun 5, 2006 | 12:21 AM
CentralCoaster
Jamming your floormats under the gas pedal would do the same, but it doesn't mean it's helping.
The Tornado is a restriction.
Old Jun 5, 2006 | 12:25 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
