Distributor Play
Old Jun 3, 2006 | 05:09 PM
Mtrhd329's Avatar
Mtrhd329
Default Distributor Play
Anyone know how to solve the problem of a distributor that will rock back and forth about 15-20 degrees? Its like it isnt tight but i know it is. I have heard about putting some washers between the dist and intake manifold? is this a good fix?
Old Jun 3, 2006 | 06:21 PM
mseven's Avatar
mseven
I have never heard of that, nor would I attempt to alter the allignment between the cam gear and distributer gear. Shimming the end play in the distributer is a good idea. Distributer shims can be purchased through summit etc. I would also inspect the gear for wear, bearings, and straightness of the shaft itself.
Old Jun 3, 2006 | 06:28 PM
comp's Avatar
comp
,,the dist. can sit to low in the block but i don't know if it will make that much difference
Old Jun 3, 2006 | 08:10 PM
CFI-EFI's Avatar
CFI-EFI
The distributor moves? What, exactly do you mean by "rock back and forth"? Does the distributor rotate? Jump up and down? I can't picture "rocking". How do you detect the "15-20 degrees", which one heck of a lot?
RACE ON!!!
Old Jun 3, 2006 | 11:34 PM
AKS Racing's Avatar
AKS Racing
Do a search for a thread called "15° Retarded". This is discussed in that thread a few weeks ago.
Aaron
Old Jun 4, 2006 | 09:35 AM
Slalom4me's Avatar
Slalom4me
15° Retarded
This thread and the one about the worn distributer gear
are both of interest to owners of cars with a number of
years/ miles on them.
Old Jun 4, 2006 | 09:44 PM
Mtrhd329's Avatar
Mtrhd329
Thanks for the inputs guys... I was able to move the rotor back and forth by hand about the distance of one post on the distributor. From what the other posts said i need to shim the gear i guess. Are there instructions with the shim kit. I have replaced and removed many distributors but have never taken any apart or shimmed them. how do i measure for sure how much play i have?
Old Jun 4, 2006 | 11:01 PM
AKS Racing's Avatar
AKS Racing
No instructions with kit. Use feeler guages to determine the amount of gap that need to be removed, then use shims to remove that amount. A quite simple project that is cheap.
Aaron
To Distributor Play
