Brake Fluid Cup Gormmet
Old Jun 3, 2006 | 06:53 PM
newguy84's Avatar
newguy84
7th Gear
Default Brake Fluid Cup Gormmet
I replaced the master cylinder on my 84 several months ago. I recently noticed that the rear brake fluid cup was leaking. I had goofed up the grommet a little when i forced the cup onto it. Is there a trick to doing this? I ordered a new grommet that will be here monday and I'll have to fix it.
Old Jun 3, 2006 | 08:05 PM
bogus's Avatar
bogus
I would hit the grommet with a touch of marvel mystry oil...
Old Jun 3, 2006 | 08:14 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Installing the grommet is a PITA. I found a piece of pvc conduit from Lowes that was the perfect diameter and used it to push the grommet in straight so it did not get messed up. Lube it up with a little brake fluid to make life easier. Still a PITA, tho.
To Brake Fluid Cup Gormmet
