1995 C4 - My right headlamp door actuator continues to run long after the door opens. The actuator output shaft makes about 3 revolutions which results in the door opening and closing about 3 times then stopping about halfway open. This appears to be either the actuator or the control module.....
Is there a simple test to identify which one is guilty? (I have replaced the Delron bushings but that made no difference. Also tried to power the right actuator from the left side harness but not sure which of the 5 wires actually drives it in the opening mode). Any recommendations or solutions would be appreciated.
