86 C4 not cranking help help help!!!
Old Jun 6, 2006 | 05:28 PM
smilen_31's Avatar
smilen_31
6th Gear
Default 86 C4 not cranking help help help!!!
yesterday I completed putting in a new power sterring pump and new fuel lines. After putting everything back toghether tha car will not crank. I have looked at the wiring and it seems that everything is back toghether. I have bought a new battery and tried 3 different keys because it seems like a security delay. Does anyone have an idea or can you tell me how to bypass the security system. I hear the fuel pump when I try to crank I get nothing
Old Jun 6, 2006 | 10:27 PM
lefoy84's Avatar
lefoy84
check the crank wire going to the starter solenoid. I think its purple. Maybe you knocked it loose. The fuel lines run fairly close.
Old Jun 6, 2006 | 10:50 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Here is some good reading from the 86 bible
http://members.shaw.ca/agent86/Start...g%20System.pdf
http://members.shaw.ca/agent86/Vats%20Electrical.pdf
To 86 C4 not cranking help help help!!!
