L98 Ignition Upgrades
Old Aug 27, 2001 | 08:54 PM
1990PoloVette's Avatar
1990PoloVette
Default L98 Ignition Upgrades
I know this subject is always beat to death :smash: but what upgrades should I make, if any, to my 90'. All I can confirm at this time is that it has Accel 8.8 plug wires on it and a stock cap and coil. Dont know what plugs are in it.... What can I expect from any changes ?? Suggestions would be appreciated. Thanks :cheers:
Old Aug 27, 2001 | 09:24 PM
DON M's Avatar
DON M
Default Re: L98 Ignition Upgrades (1990PoloVette)
Ya know, every one here seems to put down the MSD boxes. Every Winston Cup car has two under the hood. The're not so much for WFO, but to keep the plugs clean during pit stops and cautions. I'm a believer.
The other point is to use a cap and rotor that have brass posts inside (Accel and others). There is also a thing called a Dyna Module that increases dwell time in the distributor. It replaces the ignition module. I haven't got one yet, but it sounds good. The caveat here is that any non stock part is subject to failure at a greater rate than GM. But then again some are better than stock.
Good luck,
DON M
Old Aug 27, 2001 | 09:30 PM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
MSD definatley is a cost effective way to upgrade your ignition, plus have plenty to handle any future upgrades, i know it will probably come up so i have taken a picture of how i mounted mine. It was mounted up under the passanger side headlight i will post some pics when i get home
Old Aug 27, 2001 | 09:50 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: L98 Ignition Upgrades (91_Corvette)
I like the HyperTech coil/cap/rotor assembly.
For spark plugs, just cut back the electrodes on AC Delcos and with the HyperTech setup and good wires, gap em to about .045"-.050" (10 HP gain, better gas mileage, lower emissions and it's free...such a deal).
Old Aug 28, 2001 | 09:19 PM
1990PoloVette
Default Re: L98 Ignition Upgrades (65Z01)
:blueangel:
Old Aug 29, 2001 | 04:12 AM
importeater's Avatar
importeater
who in the world would put down msd? they have a great kit for the HEI with a 6al box, coil, wire & harness. helps the revs over 5000 quite a bit. also everyone has there 2 cents on plugs and mine go to bosch...they are BY FAR my favortive plug, taylor & msd are the favs for wires.
Old Aug 29, 2001 | 04:14 AM
Kale's Avatar
Kale
AC Delco Rapidfires - best plugs for hte l98
Old Aug 29, 2001 | 12:00 PM
Paul G's Avatar
Paul G
Default Re: L98 Ignition Upgrades (Smash)
What do you mean cut back the electrodes? Do you mean the center electrode or the one you bend to get the gap correct? How much do you trim.
Old Aug 29, 2001 | 12:30 PM
65Z01's Avatar
65Z01
Default Re: L98 Ignition Upgrades (Paul G)
I trim the ground electrode back to the near edge to the center electrode and trim all edges with a fine file to remove any burs or sharpness.
Old Aug 29, 2001 | 12:33 PM
scorp508's Avatar
scorp508
Default Re: L98 Ignition Upgrades (importeater)
Thtas Great..... for when you need it. Now lets just upgrade the TPI so that it breaths over 4800. :D I do hear that the MSD smooths out the idle, is that true?
Old Aug 29, 2001 | 12:38 PM
Rick86's Avatar
Rick86
Default Re: L98 Ignition Upgrades (DON M)
Why do you think they have two? They go out when unexpected. Now I know they have them set to different rev limits, but how often to you hear the driver radio in that the ignition is cutting out and he is switching to the back up?
Old Aug 29, 2001 | 02:32 PM
No Ordinary 91
Default Re: L98 Ignition Upgrades (Rick86)
i haven't had any problems with mine and have it wired up so that if it does fail all i have to do is change a few wires and it will be running off the stock ignition again, takes 5 minutes in the dark :D
To L98 Ignition Upgrades
