C-4 rear suspension
Old Jun 7, 2006 | 03:17 PM
footloose's Avatar
footloose
Cruising
Default C-4 rear suspension
I have a 1996 rearend and suspension that I would like to replace all the rubber bushings. I can't seem to find any, do I have to replace the control arms?
Old Jun 7, 2006 | 03:31 PM
bogus's Avatar
bogus
yea, if you want rubber.
why are you replacing them? they should still be ok, unless you have uber high miles.
poly is available, tho.
Old Jun 8, 2006 | 08:55 AM
footloose's Avatar
footloose
Cruising
Default suspension bushings
They are dried and cracked, I think I will get to much movement with existing ones. I perfer rubber over urethene because of a smoother ride. Where do I find bushings?
Old Jun 8, 2006 | 09:17 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
I'd give vansteel a call and ask them. www.vansteel.com
Old Jun 18, 2006 | 12:13 PM
LS7-EB's Avatar
LS7-EB
Default footloose
Check out Energy Suspension, they have all the urethane parts you could want.
Also, Dick Guldstrand, in Burbank, CA, 818-558-1499, has control and toe in bars with heim joints, that's what I have.
EB
To C-4 rear suspension
