inverter question
Old Jun 9, 2006 | 07:26 PM
ED HEISER's Avatar
ED HEISER
Default inverter question
Does anyone know how big an inverter is needed to run a 1.8 cubic foot refrigerator? The frig says its 5.4 amps max, but a 1200/2400 watt inverter won't do it. The inverter runs my 15 inch flat screen TV just fine so I know it works. I know the start up is a heavy load, but it must be more than 5.4 amps or 1200 watts would do it (120vX5.4amps=648watts). Anyone know where I went wrong in my calculations?
If you are wondering how I got all that in my C4......it's in my boat. Nobody seems to know sh*t about this at the marine stores I've tried, so I thought I'd give you guys a try.
Old Jun 9, 2006 | 07:44 PM
_twisted_'s Avatar
_twisted_
I think your resistive load rated on the inverter, the fridge must have a comp and draws big on start - there should be a sticker on the comp showing max draw
Old Jun 9, 2006 | 08:20 PM
aminnich's Avatar
aminnich
Your math is fine, it is the start-up draw on the compressor that you need to finds out. But then why not just get a 12V refrigerator?
Old Jun 9, 2006 | 11:39 PM
jfb's Avatar
jfb
Starting current is about 2.5 times running current. For your fridge its 13.5 amps x 120 volts = 1620 voltamps. Another factor is that the lower cost inverters do not supply a sine wave to the load and motors don't like the squarish type waveform supplied by inverters. A, "modified sine wave", is not a sine wave. A higher power inverter might start your fridge, but try it out before you buy another one.
Old Jun 10, 2006 | 11:18 AM
ED HEISER's Avatar
ED HEISER
Thanks for the replies. I can get an AC/DC refrigerator, but they run $750 to $1000. I bought a perfectly good AC frig for $69 at Walmart that fits. If it quits like my original I'm, not out another grand. Since I wanted an inverter for my TV/DVD when at anchor anyway, I thought I would kill two birds with one stone and get a 1200/2400 (the 2400 is peak or surge power) for $99 at Kragens. I now see that the peak power does not last long enough to get a compressor going. If the 2.5 factor is correct, I need a 1700/3400 inverter at least, maybe more. I will check out the return policy before I buy again. I have room for a second inverter and another battery, I may go this route. I may also get a Sine wave 3000/6000 for $699 and try my shore power A/C unit also to avoid a costly($4100) and noisy generator. It's hard to get good advise on this subject, as the marine aftermarket industry is old school and everybody is an "expert" until you give them your money and find out later they were wrong. Kinda like getting your C4 modified/fixed.
Old Jun 10, 2006 | 11:56 AM
aminnich's Avatar
aminnich
We sell 12V refrigs and 12V TV/DVD for less than $200 each all day long for truckers here in Georgia.
Old Jun 10, 2006 | 10:22 PM
comp's Avatar
comp
where is that ????
To inverter question
