Gas guage problem
Old Aug 28, 2001 | 10:20 AM
Kevin McGrade's Avatar
Kevin McGrade
Default Gas guage problem
Looks like it is stuck. I filled up a couple of time coming back from carlisle and it does not want to come down past 3/4 or so.
Anybody ever have this problem and what is the fix??
Old Aug 28, 2001 | 11:42 AM
Flame Red's Avatar
Flame Red
Default Re: Gas guage problem (Kevin McGrade)
I would say that it is probably the sender unit that is contained in the tank. Easy to replace, but large $$$$$$$$$ :(
The Last Detail is a good source.
Flame Red
Old Aug 28, 2001 | 11:49 AM
SLEV89's Avatar
SLEV89
Hi Kevin,
pretty common problem with vette (GM) gauge.
i'll assume that the '92 wiring scheme is colored the same way as the '89.
my gauge had been reading high for a while. at one point, it read full scale constantly so i decided to finally tackle the level sensor. very easy job.
the Fuel Lever Sender's connector is behind the rubber 'boot' at the gas filler spout - you can test your sensor there easily.
if you jumper the Purple wire to the Black wire and try the ignition ON, the guage should read zero. if so, there is definitely a connection problem wiith the Fuel Level Sender.
the Fuel Level Sender, when disconnected from the vehicle, should read 90 ohms in full position, and near zero ohms at empty (measure between Purple wire and Black wire).
make sure you disconnect the connector from the vehicle harness so that you don't damage the electronic dash with the ohmmeter!
there is a really simple resistance slider (potentiometer) attached to a pivoting float/arm. REALLY simple.
on mine the copper 'rivet' that slides across the resistive element had a bad (high resistance) contact with the little tab that it is mounted on. i had to 're-squash' the rivet to make it tighter in its mooring.
and, whalla, she back in action.
the gauge/pump assembly slips out from the top, at the fuel filler nozzle.
simply remove the Flip Lid bodypanel and the Rubber Boot from around the filler spout, and the rest is obvious.
feel free to e-mail or Instant Message for any clarification :seeya
paul
Old Aug 28, 2001 | 11:56 AM
SLEV89's Avatar
SLEV89
Default Re: Gas guage problem (SLEV89)
let me say that in another way:
DO NOT connect an Ohmmeter to any electronic device (Instrument Display / Climate Controls / Stereo etc). Ohmmeters use their own battery power and can destroy electronic elements
- the Fuel Level Sender is not electronic, just a big clunky wire.
- but, the dash Instrument display IS and can be fried quickly!
Old Aug 28, 2001 | 03:04 PM
John Row's Avatar
John Row
SLEV89,
You should post this under Tech Tips.
My gauge reads FULL-3/4-Reserve about half of the time the rest of the time it seems to work nomally.
Looks like I'll be pulling the sending unit.
Thanks,
Old Aug 28, 2001 | 10:30 PM
akros's Avatar
akros
my 96 read full all the time until I disconnected the battery for awhile, that fixed it.
Old Aug 28, 2001 | 11:12 PM
dsky's Avatar
dsky
i had asked this same question, thanks for your input.
regards
doug :jester
To Gas guage problem
