C5 Brake upgrade help
1. The brake calipers do not have a LH/RH designation on them. Am I missing it or are they the same.
2. I am using the Hawk pads. Two of the pads have metal clips on them. Are these the outer or inner pads? Is the metal clip at the top or bottom?
Thanks in advance.
Although I'm not certain, I believe the clips are the wear indicators -- when they hit the rotor, pads are gone. At least that's the only thing I could see them being there for.
So, I used them on the outboard side with the clip on the bottom. One word of warning on the upgrade. Make sure the anti-rattle clips fit properly. The set I got were too wide and scraped against the rotor -- didn't hurt anything but made an awful sound until I figured out what it was. Simple trim with a dremel and the problem was solved.
You'll love the upgrade. Significant improvement over the C4 brakes. Look good too....
http://forums.corvetteforum.com/show....php?t=1407022
Definitely, always! Generally the indicators go inside so they can be seen from under the car. I think they usually go on the leading edge of the pad too, at least on the pads I've seen that were marked L and R.
