How to replace leaf springs?
Old Jun 11, 2006 | 07:14 PM
Stingraynut's Avatar
Stingraynut
Default How to replace leaf springs?
Has anyone got any info or links to info on replacing the transverse leaf spring?
I hear the rear is easy but the front is difficult -
S'nut
Old Jun 12, 2006 | 05:08 PM
chucks88's Avatar
chucks88
Not too tough just took some time. I researched how to do it by searching hear on CF. Do a few searches for "lowering" "spring removal" that sort of thing and you'll even come across a few pics.
You'll have to get the front up pretty high to get that spring out, You'll have to disconnect your lower shock nut, split your lower ball joint, split your outer tie rod. ETC
