More horniness...
Old Jun 12, 2006 | 05:33 PM
bsmutz's Avatar
bsmutz
Default More horniness...
Had the whimpy horn problem and decided to find out what was up Saturday. Turned out the horn on the passenger's side was toast. I wanted to pass along that the horn will work without being mounted. You can plug one side into the harness on the other side to check it. When I looked for a replacement on line, I couldn't find an exact duplicate. I have no problem changing connectors if necessary, but wanted to check here first. Anyone know a place to get an exact replacement? It's for a '91 and has a small oval shaped connector that is keyed (key looks like a small mushroom). Connector innards are small two small blades about 3/8" long and 3/32" wide.
