Heater blower motor dont stop
Jun 12, 2006 | 02:31 PM
Cruising
My C4 87 ...the blower motor does not stop after shut down ..key out.
It keeps running at low RPM ...Whats wrong?
Polaris10
Jun 12, 2006 | 02:38 PM
blower control module
Jun 12, 2006 | 02:39 PM
Jun 12, 2006 | 03:08 PM
What system - Electronic or Manual?
Jun 12, 2006 | 03:24 PM
Cruising
Quote:
Electronic ...its the auto function ...you set temp and it control fanspeed
Jun 12, 2006 | 03:39 PM
Cruising
Quote:
Originally Posted by AGENT 86
Thanks AGENT 86...that should keep me busy for some time...but has anyone had the same problem...It started as my battery went bad , just had a few Volts in it and then after replacing to a new one Fan runns all the time. I will start to lock for a burnt down releay somewhere close to motor..Iguess
Jun 12, 2006 | 03:51 PM
86 said its the blower control module and its 99.9% chance he is right
there is a 5 amp fuse on the fire wall that could be blow, about .1% chance
Jun 12, 2006 | 04:21 PM
Cruising
Ok.. were is that module located? Is it a sep module or integreated on a circutboard.
Jun 12, 2006 | 11:51 PM
Quote:
left hand side of evaporater housing
