I hate Monday's....
I then heard the whine... oh, yea, baby, the alternator dropped a brush.
Great. The voltage is down to 11.7, I turn off everything electric, and it peaks back up to 12.5~12.9, but that's about it. One brush is still charging.
I get it home, call NAPA, get another reman (junk, but time is now of the essence) and install same.
Oh, the last couple of weeks, I have been fighting an H15 code... Yesterday, switched over to the coolant display, and guess what! It would hit about 130~140F, and would go
!!!! It would climb to that temp range, then drop to LO, bounce up to 80, drop to 39, up to 67, down to 39, and then start to work again somewhere about 145. Well, H15 will cause the engine to SHUT DOWN!!!! I would have to flood start it to refire... now I have a new sensor.
See? One helluva Monday morning, eh?
Thanks, Matt
Shame on you, Bogus!!
Larry
code5coupe
You can pick up replacement brushes for your original alternator for a few bucks, and it's one of the easiest repairs you'll ever make. All you'll need is basic hand tools and a paper clip to keep the brushes stowed until the housing's back together. I recommend it!
Glad to hear you survived the First and Second Mondays of the Week. Sour milk = yuck!!!
(PS: your alternator wasn't charging at all if one brush was absent -- without both brushes making contact to the slip rings, there will be no current flowing in the field windings).
Be well,
SJW
Larry
code5coupe
Be well,
SJW
It was making a funny humming sound and smelled strong of ozone... so something died in there. I assumed it was a bad brush.
I didn't have the time to consider rebuilding it... mainly, if it wasn't the brush, I was out that much time to redo it. So screw it.
Be well,
SJW
the reman I installed was actually a NAPA part this time. I am hoping it's better than the junk at Autozone and such.
I returned the old Kragen POS for core. I just don't have the time to deal with it. One day, when all the projects are done, I am going to order a brand new AC Delco unit... and be done with it.
But he smelled ozone, which indicates arcing was occurring (most likely at a failing brush/slip-ring interface).
But, it's all academic at this point, as he's already turned the dead unit in as a core...
Be well,
SJW
Be well,
SJW
Top that off with a sound and vibration issue.
Something internal was rubbing in a very bad way. I don't think the diode bridge, on it's own, would do all of that.
Thats a bitch
