88convertable
Old Jun 13, 2006 | 07:07 AM
warrior2291's Avatar
warrior2291
Default 88convertable
does anyone know how to change the bulbs for the 3rd brake light on a 1988 convertable?
Old Jun 13, 2006 | 08:51 AM
mudslide's Avatar
mudslide
On my 90 vert I think you can get it by taking out the gas filler assem. Should be the same for yours check the FSM
Old Jun 13, 2006 | 09:07 AM
The Hobbit's Avatar
The Hobbit
On my 86 you can pull the rear number plate and then get to the 4 10mm nuts holding the stop light unit, undo these and take the whole thing out through the number plate hole. You can then dissasemble it and chang the bulbs
Barry
Old Jun 13, 2006 | 10:19 AM
89sleeper's Avatar
89sleeper
From: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
Are you sure it is a bad bulb and not a bad brake light switch?
When my 89 roadster 3rd brake light was not working a new brake light switch got it working again
Old Jun 13, 2006 | 11:05 AM
fastrtnu's Avatar
fastrtnu
From what my manual says for my 87, you need to take apart the fuel filler assembly and unbolt it from the top and then pull it out through the license plate opening. Let me know how long it takes to do as I've got to do it as well.
Old Jun 13, 2006 | 11:40 AM
warrior2291
Default 1988corvette
thanks everyone I will check it out tonight.....only one side of it is out thats how I fughured it had to be a bulb.the other half lights up fine
To 88convertable
